50 Years Of Bultaco
Big John: Where do you hide that bike???
It is not in your garage. Maybe under your bed???
Oh yes Greeves, it was there in the corner of the Batcave! Did you not see it?
You were too busy with the 340 and complaining about the carburation of the Bing!
Big John
  • Replies 101
  • Views 41.9k
Too many bikes there...... you need to make some space....... maybe one Matchless lessss makes enough space for you to move arround.
I am quite busy this days, but will post some photos soon of my new weapon for the Spanish Champ. starting in Mallorca island next 2nd. March. A completely rebuilt Bultaco 340 Puma Racing. A beast not even Vesterinen would had ever dreamed to drive something like that...... :banana2:
Yes Greeves, you are quite correct!
As I speak No.1 son is polishing the model 49 for the Scottish Show!
I cannot wait to see the special El Puma Racing 340!
Big John
Here it is; THE BEAST.
Wow, that bike is stunning - how much would a bike like that cost to buy today?
I'm hankering after an old bike, it must be my age :)
Ok let's see;
Rear box modded to single outlet
Front pipe extended
Modern footrests
Chain adjusters moved inside swing arm
Front mudguard stay
Extra cylinder head support to the front
Different carb
Gas assisted rear shocks
Thinner seat
Chain guard
Sure there are more goodies internally and probably more externally that I have missed.
I've tried to use front mudguard clamps like that in the past but they are too small in diameter to fit over the Betor forks.
What are they off - any idea Mr Greeves? or are they made by Puma specially for the Betors?
Also - what is the back mudguard. I've noticed these on several bikes from pictures on Todotrial but can't work out what they are. Any idea? (re-shaped Gonelli?)
Lovely bike.
Ok let's see;
Front pipe extended
Modern footrests
Front mudguard stay
Different carb
Thinner seat
Chain guard
1.- Rear box; yes single outlet and modified interior to allow an easy exhaust.
2.- WRONG. The chassis is strictly original, maybe you think that because of the paint in the tank.
3.- YES, with modified position, slightly rear.
4.- It is the original ona but slightly shorter.
5.- Yes, to make the forks more "rigid".
6.- Yes, to reduce vibrations in the hole "thing".
7.- Just a PHBH that actually existed when this bike also existed, not illegal.
8.- Yes, Mick Andrews design and development (sorry no publicity permited).
9.- Yes, the seat is a modification of the original one.
10.- Home made chain guard.
There are some more. Nothing that you can
Lovely bike.
You need to work in the Betor sliders to modify them and fix the clamps.
Correct, rear mudguard is striclty original, some time spend to cut it properly. (and some mudguards spoilt while learning)
Edited by Greeves
Snr Greeves,
A very nice addition to the stable, was that the 340 I rode two years ago, but not in the trial back from Jose Luis Rodriguez..."EL PUMA"?
Big John
Snr Greeves,
Big John
Yes, it is the one you rode arround Berrocal, as you didn
Edited by Greeves
Cream.
You should be able to kick some a*** on her Greeves.
Any work been done in the cylinder.
Cream.
Hi bilc0, inside the cylinder just the transfers opened (maybe "rounded" is more correct) a little.
Have you started the countdown for Robregordo?? We will have a special event there for the 50 years of Bultaco.
Edited by Big John
