February 14, 201016 yr Hello i changed the rear tire from my beta Rev 3 4T. Afther that the tire runs flat afther a 10 minutes ride. Before i put on the michelin X11 - light there was a Michelin trial - comp on the wheel. What could be the problem? Greathings Luc (the belgium trial guy)
February 14, 201016 yr Paint on some diluted washing up liquid and see where the air bubbles are escaping from, this will help you locate the problem.
February 14, 201016 yr X lites will go down, mine did but not as quick as that, did it pop twice when you put it on? I'd de-flate it and blow it back on again Edited February 14, 201016 yr by The Addict
February 15, 201016 yr Careful not to toutch the rimtape as you may dislodge it on a tire change. Leaks follow!
February 15, 201016 yr Author Hello do all trials tires will go down afther a ......minutes? I'm thinking about a vacation in Spain and will ride day-trips (+/- 60 km a day). To pump up the tire every ...minutes is not an option. ??? Do i have to place an inner tire? Greathings Luc
February 15, 201016 yr Sounds like it needs a new rim tape! Take the tyre off, remove the rim tape and give it a really good clean. Get some silicone and put a dab on the end of each spoke (inside the wheel, under where the rim tape would be) let it set then put a new rim tape on, replace the tyre and you shouldn't have any problems after that. Had to do this with my wheel, the air would escape through the spokes within half an hour! Has worked a treat and stays up permanently now!
February 16, 201016 yr Author Hello i found the leak...one of the spokes is the problem. Now just put some silicone on and ride again. Grtz Luc
February 16, 201016 yr Surely the rim tape is the problem then, air shouldn't be passing that to get to the spokes.
February 18, 201016 yr Author Silicone does not help. The rimtape will be the problem. Going to change that. Luc
February 18, 201016 yr Yes, had the same thing when I damaged the rim tape changing a tyre on mine. I never could get it to seal properly again but as mine takes 24 hours to loose 1psi, I put up with it. Fitting the new rim tape was one of the most frustrating things I have ever undertaken, you don't know if you've been succesfull until you refit the tyre and pump it up. After five or six goes, I just plastered silcoflex on the tape and gave up trying to do it properly. People will tell you there's a knack for doing it and once you've got that then it's easy, but I certainly haven't got the knack. Good luck and let us know how you get on. Pete
February 19, 201016 yr Yes, had the same thing when I damaged the rim tape changing a tyre on mine. I never could get it to seal properly again but as mine takes 24 hours to loose 1psi, I put up with it. Fitting the new rim tape was one of the most frustrating things I have ever undertaken, you don't know if you've been succesfull until you refit the tyre and pump it up. After five or six goes, I just plastered silcoflex on the tape and gave up trying to do it properly. People will tell you there's a knack for doing it and once you've got that then it's easy, but I certainly haven't got the knack. Good luck and let us know how you get on. Pete He, he , you pus!
February 24, 201016 yr Hi, In my opinion i would put an inner tube in and a security bolt!! as i do with my 4t and all other trials bikes i have owned.I just dont think the rims seal very well especially at such low pressures. Doug.
