Scorpa Sy250
shazsdad
  • Replies 55
I haven't got a photo but I can get one within the next day or two.... Hang on, I've got one for now..... Just need to do a bit of trickery pokery... There! The red circle is where the flap bolts on with three bolts to the lower part of the airbox.
I did have a smile on me face when I saw you have posted in the 'Scorpa' section :ph34r:
Hopefully riding your trial m8, The SY's frame has gone off to be powder coated today, chap says it should be back by Friday ;) so Fingers crossed ;)
If I aint got a ride I'll come along and mark a board :hl:
Vinnie,
I added a mudflap to my 125. Made my own with 4mm thick rubber, pop rivetted thru the airbox with large head washers to stop them pulling thru.
Works a treat, stops loads of crap getting past.
One lad in the centre has fitted the SY250 subframe and airbox (with the flap) to his 125. Requires a bit of fabrication work, but the advanteage as well is that you can fit the 250 mudguard.
Quite a costly mod tho........
cheers
John.
Vinnie,
cheers
John.
Would you have a Photo
Vinnie
