September 17, 201016 yr I took my GG Pro engine out for service and it weighed 40lbs (18.143kg). Does anybody know the dry weights of Sherco, Beta, Scorpa, Montesa engines?
September 17, 201016 yr Somehow when I saw this topic it just had to be from over the pond Think ill take me wifes Audi TT engine out service it n weight it just for the laugh. Only in America, thank god its far enough away.
September 17, 201016 yr All you need to know is all the others are heavier then a GasGas. Now go put it back together and just ride it !
September 17, 201016 yr Hi Guys I changed the oil in my 300 Raga the other day. 450mls came out and it weighed 469.223 Grams. I measured 450mls of the same oil to put back in and this weighed 469.445 Grams. Has enybody else weighed other oils. I'm thinking if there are lighter oils out there i can use, it will help me in my weight reduction.
September 17, 201016 yr It's a perfectly reasonable question though I would expect the Gasser to be lightest. It is a weight obsessed sport after all.
September 17, 201016 yr Hi Guys I changed the oil in my 300 Raga the other day. 450mls came out and it weighed 469.223 Grams. I measured 450mls of the same oil to put back in and this weighed 469.445 Grams. Has enybody else weighed other oils. I'm thinking if there are lighter oils out there i can use, it will help me in my weight reduction. You may do better going to the toilet before riding a section.
September 17, 201016 yr It's a perfectly reasonable question though I would expect the Gasser to be lightest.It is a weight obsessed sport after all. We know were only having a laugh. All seriousness, i put bets on the Mont being the heaviest! Edited September 17, 201016 yr by hrc_monty
September 17, 201016 yr All seriousness, i put bets on the Mont being the heaviest! Mmmm im thinking Ariel 500cc might be heavier. Personally i Buzz cut my hair to a grade 1# thus significantly reducing my overall competeing weight.
September 17, 201016 yr Hi Guys I changed the oil in my 300 Raga the other day. 450mls came out and it weighed 469.223 Grams. I measured 450mls of the same oil to put back in and this weighed 469.445 Grams. Has enybody else weighed other oils. I'm thinking if there are lighter oils out there i can use, it will help me in my weight reduction. 550ml of oil should weigh less than <550 grams or oil wouldn
September 17, 201016 yr If i fill my tyres with oil then will i just float over all that orrible mud and water ? Acksherly wonder if anybody has thought of helium in their tyres ? At least cause a laugh if you got a punctur e
September 17, 201015 yr Okay here is me findings, Montesa heavy, Beta less heavy, Sherco even less heavy, GasGas less weight of all as usually in bits requiring a rebuild Oil i find that Olive Oil light to be the lightest of all oils and low in saturated fats, thus reducing the onset of obesity.
September 17, 201015 yr I am lazy and fat, I never clean my 315r! Can anyone advise if the extra few grams of gloop is increasing the un-sprung weight of my wheels causing me bad results. Would it be worth running bald tyres to combat this? Edited September 17, 201015 yr by Mrwhite
September 17, 201015 yr I am lazy and fat, I never clean my 315r! Can anyone advise if the extra few grams of gloop is increasing the un-sprung weight of my wheels causing me bad results.Would it be worth running bald tyres to combat this? No Fat and bald is never a good look in my honest opinion.
