What happens when your bike runs out of fuel?
Have any of you been in high rev situations while in gear as your bike is running out of gas? Any stories and/or crashes? When my bike runs out of gas, it revs like crazy for about 20 seconds (it's horrible for everything, now I know that it sucks up more gas than I thought it did). Is it possible that I have an air leak since the revs last this long?
What has been your experience(s) regarding lean fuel conditions?
Basically Air cooled engines rev like crazy until they burn off any remaining fuel. Liquid Cooled just die.
if it's in the scott you have a long bloody push.....
The runaway revving thing as the fuel level in the float bowl goes low can be due to the lean mixture causing detonation instead of the controlled burning that normally happens.
It can also be due to the idle mixture being too rich, then becoming correct mixture as the fuel level goes low.
No it can't be due to a vacuum leak, because it would do it all the time that the motor was at normal operating temperature, not just when it was running out of fuel.
ha ha :)
When your bike gets to the point of empty it goes lean and atomizes the fuel greater than the 14:1 ratio that is normal, causing a VERY lean mixture thus making the engine run away!
Edited by BillyT
I can hear my engine start to ping before it stalls out usually. Mine revs up before it dies too. I find it hard to start if I let it run completely out of fuel so as soon as I hear the pinging I shut her down and top her up.
