November 13, 201115 yr hi all i have the 199A i use NGK is there an up grade that i can get? Not sure, you can make a downgrade to the old plugs the engine could use like: - L
November 14, 201115 yr Hello Bondy. I have been using a NGK B6EV in my Sherpa for the last two years or so. I think I got the last four in Australia though. You should be able to get a BP5EGV though as they use them in a lot of high performance cars. The thin electrode does sharpen the power on the Sherpas up. The iriduim plugs are also worth a look as well. There is a NGK website to look at but I am not sure of the address though. Bully Lover.
November 14, 201115 yr Author Hello Bondy. I have been using a NGK B6EV in my Sherpa for the last two years or so. I think I got the last four in Australia though. You should be able to get a BP5EGV though as they use them in a lot of high performance cars. The thin electrode does sharpen the power on the Sherpas up. The iriduim plugs are also worth a look as well. There is a NGK website to look at but I am not sure of the address though. Bully Lover. ok ill have a look thanks for the info guys
December 8, 201114 yr What plug is recommended for an M80? I did start it up first time ok on an NGK B7ES, because that's what I had in my garage. But now I can't start the b'stard. Is there a technique for starting them? I'm used to starting big 4 strokes, where there is very definitely a technique - but probably not right for a little 2 stroke. Any suggestions? There's plenty of petrol getting through.
December 9, 201114 yr http://www.sparkplugs.co.uk/ are very good. avoid lodge and champion. Champion seem a bit better these days, they were all I could get, and have been OK.
December 11, 201114 yr I use ND (Nippon Denso) - used to use them in the race bike and they always gave more power than NGK. Never had a problem with them. You can get the correct equivalent from the previously mentioned www.sparkplugs.co.uk - who are fantastic to deal with and good on price too.
