Size Of Ball Bearing In Clutch Actuator Sherpa T 350
hi again
any one now the size of the ball bearing in the clutch actuator lever
mines a bit crushed got it out but no way can I measure or match one up by it
ordered all my stuff from inmotion today and forgot bearing,
just wondering if anyone knows the size so hopefully pick one up tomorrow locally
cheers
not sure just ring inmotion back they will tell you. somthing ive never changed.
The original is about 5,4mm in diameter I think, but because mine was worn I put one in I had lying around which is 6mm. That's the largest one that will fit the hole.
  • 2 months later...
JUST done this today, I couldn't fit a 6mm, but a 5mm went in ok.
In the parts book it says 5.5mm.
Paul
  • 4 years later...
Hello paul how did you get the old ball bearing out the clutch Arm? also how do you replace it as I have 1 that needs replacing :blink:
Bondy - Check date of first post .......  :o
yes its a while ago I need to find out how to get the old flat bearing out and replace it with new:P
