harrytrialsboy Posted June 10, 2005 Share Posted June 10, 2005 when my riding my pro up the road in the higher gears there appears to be like an on and off knocking at gentle revs or i cnt quite explain it at first i thort it mite be the disk guard or something but it sounds too close to the engine .any one got any ideas or am i jus over acting and also how long shud it take for the fan to kick in mine comes in after about 5 10 mins ive checked the coolant level its full, again any ideas?????????????Thanks for anyfeedback in advance much appreciated Quote Link to comment Share on other sites More sharing options...
ba baraccus Posted June 10, 2005 Share Posted June 10, 2005 Not sure about the noise? As for the fan, mine doesnt take long to kick in either! It maybe due to the small radiator thus allowing the coolant to heat up quicker? Think its pretty normal tho? Quote Link to comment Share on other sites More sharing options...
harrytrialsboy Posted June 10, 2005 Author Share Posted June 10, 2005 ok cheers mines only a 200 any way so your probably right Thanks m8 Quote Link to comment Share on other sites More sharing options...
ba baraccus Posted June 10, 2005 Share Posted June 10, 2005 Thats ok, mines a 200 as well Quote Link to comment Share on other sites More sharing options...
jools Posted June 10, 2005 Share Posted June 10, 2005 The fan cuts in on mine after around 10 mins so yeah thats normal. Dunno what the knocking is. Is it pinking?? Quote Link to comment Share on other sites More sharing options...
marky g Posted June 10, 2005 Share Posted June 10, 2005 It's a normal sort of noise for a GG, in the end it explode into a thousand bits and you'll have to buy a new one ..clever marketing by GG I'd say Quote Link to comment Share on other sites More sharing options...
harrytrialsboy Posted June 10, 2005 Author Share Posted June 10, 2005 its just a bit of a noise when i come off the revs going steady speed sounds a bit like when the chains dry but tiny bit louder????????????? Quote Link to comment Share on other sites More sharing options...
bikespace Posted June 10, 2005 Share Posted June 10, 2005 How worn are your chain and sprockets? Are the sprockets hooked at all? Just a shot in the dark really. Quote Link to comment Share on other sites More sharing options...
Andy Posted June 10, 2005 Share Posted June 10, 2005 Thanks m8 Two emails telling you no text talk allowed and you're STILL doing it! Quote Link to comment Share on other sites More sharing options...
perce Posted June 11, 2005 Share Posted June 11, 2005 It's a normal sort of noise for a GG, in the end it explode into a thousand bits and you'll have to buy a new one ..clever marketing by GG I'd say & this slaphead never learns much either. Why put stupid, no brain comments? Quote Link to comment Share on other sites More sharing options...
bikespace Posted June 11, 2005 Share Posted June 11, 2005 Stupid no brain comments have almost become a way of life for some, a religion you might say. In which case, under the new British law, you may be guilty of inciting religious hatred I'll be checking with my legal team. Quote Link to comment Share on other sites More sharing options...
jools Posted June 11, 2005 Share Posted June 11, 2005 & this slaphead never learns much either. Why put stupid, no brain comments? Well Said Bikespace is right, worn chain & sprocket set-up's can be noisey, worn bearings etc. worth a check Quote Link to comment Share on other sites More sharing options...
bikespace Posted June 11, 2005 Share Posted June 11, 2005 One other possibility, I used to get a knock when "blipping" the throttle from low revs, but it was much worse when running on poor fuel (ie anything less than the best). If you're not using the best fuel available then you should. It makes all the difference. Either use optimax or the best Super Unleaded you can get. Of course it could be loads of things but a couple of ideas anyway. Quote Link to comment Share on other sites More sharing options...
marky g Posted June 11, 2005 Share Posted June 11, 2005 It's a normal sort of noise for a GG, in the end it explode into a thousand bits and you'll have to buy a new one ..clever marketing by GG I'd say & this slaphead never learns much either. Why put stupid, no brain comments? Slaphead "& this slaphead never learns much either. Why put stupid, no brain comments?" Bit of a laugh PERCE, but mainly to get self righteous pricks like you wound up! Quote Link to comment Share on other sites More sharing options...
gasgaspunkuk Posted June 19, 2005 Share Posted June 19, 2005 you the man marky g, you tha man! yer mine make that noise too, and ive got new chain and sprokets, and use uptimax. i think markys comment is probs the best diagnosis lol. Quote Link to comment Share on other sites More sharing options...
