How Do You Get Oil Into Your Gas Gas ?
cwill83247
I use 60 ml oral syringe with 50mm of fuel pipe on the end of it and just do 50ml at a time so it's easier to keep track of the 350ml level, i'm lucky i get them for free, i use them for toping up the rad as well, dead easy and no mess.
I bought a few nitro fuel bottles for model cars a few years ago which come with a long thin and curved ali pipe on the top with a cap, ideal for filling for oils and coolant, and you can get them from 250cc to 1000cc.
http://www.ebay.co.uk/itm/500cc-500ml-Nitro-Fuel-Refill-Bottle-Glow-Engine-RC-Blu-/330451471726?pt=UK_ToysGames_RadioControlled_JN&hash=item4cf0714d6e
Use an atf bottle with oil of your choice and lift the front wheel as high as possible so making the filler hole vertical I put the front wheel on my bench and put the bike in gear to stop it rolling back
I found a clear plastic condiment squeeze bottle at the supermarket with a narrow spout, cost less than a dollar. It just happens to hold exactly 350 ml when absolutely full. The spout is small enough to fit inside the fill hole on the S3 clutch cover I bought which is actually smaller than the stock cover's fill hole.
Please sign in to comment
Sign In Now
