2005 Gasgas 300 Raga Clutch Movement?
Thanks guys I won't be changing the hub bush as I only bought it thinking there was supposed to be another bush on top of that one because the one in the video can be removed with a magnet.
  • Replies 33
  • Views 7.9k
Most Popular Posts
  • steve_earle
    steve_earle
    The idle gear will rattle even if it has a scratch, if you have broken teeth your problem lies there. An 05 300 Raga for a newbie, Brave man LOL.
  • Did the fan run? When the fan starts going bad, sometime it starts sometimes no. When it is going bad, you can start it with your finger. Good luck.
  • If you had the clutch cover off I reckon you haven't lined the waterpump drive up properly if it overheated.
I think the bush is (only) there because of manufacturing purposes, its easier to make a hole troughout the whole shaft and then put a spacer in it.
Edited by crazybond700
I've put it all back together with new idle gear kickstart gear but the knocking is still there.
Any ideas?
Edited by craigrevo
The broken pieces travel to the primary gear on the clutch. They become smashed between the teeth and sound like a rod knocking. It can be very hard to find. Try using a magnifying glass, and go tooth by tooth.
My primary gear had this. This is the gear on the crank. It had a very slight knick. Lukily i had an extra around to isolate. Take a nail file to each side. Fixed me up.
--Biff
Mine had it too. Also the primary gear (right one of the clutch).
Than it probably needs new clutch basket and primary gear. But try too isolite the problem first.
Is it safe to remove the clutch basket and start the engine to try and isolate the knock? If its still there it rules out the gearbox side.
I've got it apart again and I'm convinced it's the bearing that holds the clutch basket now as there is rubbing on the clutch case that I put down to old marks before. As there was no obvious signs of metal flakes, but tonight I opened the clutch pack again and there was loads of alloy flakes trapped in it.
Edited by craigrevo
Now this peace of crap is annoying me!! So far I've spent £400 on parts and still it's knocking. I've replaced
Kickstart gear
Idle gear
Clutch basket bearings
Clutch main case bearing
3rd gear half bearings
Output shaft bearing
Flywheel keyway
Crank case main bearings.
There is about 2mm of out and in play in the clutch basket but i don't know if that is normal or how to fix it if it isn't normal.
I've removed the water pump and the knock is still there, so that can be ruled out totally now.
This thing is driving me mad.
Got it!! There was a tiny dent on one tooth of the clutch basket.
B8318570-6E25-4CED-9F3A-7E437DE8A4E9_zps
So I have used a dremel to reshape it.
8ECE499E-28D6-4C70-AA3B-BE233D52FEF4_zps
Now it sounds loads better!!
Thanks for all your help and advise guys.
Well done on finding that Craig!  That must have been damn frustrating. Hope it's all good now.
At least now I know the engine is good with all the new parts, and I know what to look for in the future. Ive ordered some new shims for the gearbox to take out the slop and hopfully I will get to ride it a bit.
