September 18, 200520 yr I have a 2003 250 TXT, the rear tyre deflates over a period of time is it worth reparing if posible or should i live with it? as i dont know if it has a tube fitted Edited September 18, 200520 yr by badass76
September 18, 200520 yr Author how can i tell if it is a tubeless rear? Edited September 18, 200520 yr by badass76
September 18, 200520 yr Usually they say on the tyre if they are tubeless or not but someone could have plonked a innertube in it ? Like PERCE says its probably your spokes have you tightened them ? If not could try some sealer stuff.
September 19, 200520 yr Lick your finger and try to cover up the valve with it (nice), just to see if you've got a leak there. Otherwise, get it in the bath and watch for the bubbles. Good one to do while the other half is out
September 19, 200520 yr I have a 2003 250 TXT, the rear tyre deflates over a period of time is it worth reparing if posible or should i live with it? as i dont know if it has a tube fitted sad.gif No-one has mentioned checking the valve core or valve body for leaks. How slow is very slow - does the tyre stay up during a trial but go flat when sitting in the shed during the week? If this is the case why wory about it, 5 minutes with a footpump on the morning of a trial and you are sorted - just a thought! Find the source of the leak and fix it when you either turn the tyre or fit a new one. Edited September 19, 200520 yr by g4321
September 19, 200520 yr I do not mean to insult but guessing from your post, you may not be overly experienced with this. So, maybe start back a bit further. You should have a tubeless tire in the back, look at the valve stem, is it bolted in? Look at www.rypusa.com for the tech manuals and look at the pictures of changing a rear tire, does your stem look like that? What I do too find leaks on tires, whether it is a mower, trailer, truck or bike, is I have a spray bottle that has soap and water mixture in it. I think you guys call it Fairy liguid, we would call it Dawn, or Joy. The soap that is used to wash your dishes in the sink. Anyway, a good squirt of that in about a one quart or liter spray bottle and spray it all over your rear wheel wherever it could possibly leak, valve stem, bead area, spokes, tread, sidewalls. Pay particular attention to any area's that may have been repaired in the past (dog turds) Let this solution sit for a while and it will blow little bubbles and make a little white "cloud" where your leak is. Then, depending upon what is leaking, and if you are tubed or tubeless will determine your next course of action.
September 19, 200520 yr Gas Gas are notorious for air to leek through the spokes as perce said. Tighten your spokes up, or their is a strong possibility that 1 may have snapped. some people put tubes in tubeless tyres, and if you pump it up, it can be quite obvious if your not sure because it rounds off the profile. other than that check for flat spots in the rim etc that could disturb the bead.
September 19, 200520 yr Because I am just dying too know, and I have already been told I am incapable, just how does tightening up your spokes cause them too stop leaking.....????? Have you guys passing on this worldly advise actually done any of these? Or is this just a case of, my mind is made up, don't confuse me with facts?
September 19, 200520 yr Why are gas gas notorious for leaking spokes? they use the same rims as betas,shercos, and scorpas Btw why dont all the other bike makes use the same rim as the montesa's? as there miles better in the wasy that they dont need rim tapes and you can change a spoke without pulling the tyre off
September 19, 200520 yr Why are gas gas notorious for leaking spokes? they use the same rims as betas,shercos, and scorpasBtw why dont all the other bike makes use the same rim as the montesa's? as there miles better in the wasy that they dont need rim tapes and you can change a spoke without pulling the tyre off <{POST_SNAPBACK}> Cost and the fact that the spokes are not as easy/fast to build, and they probably want to be different.
