Mudguard
whats the best way to fix a small split in your mudguard on a 98 gas gas ? And dont say buy a new one i know what you guys are like.
For a start if you drill a small hole a the very end of any crack or split - That should stop it 'running'
but that would make it look even worse because theres nothing missing from it just split it goes together if you put it in the right place! Just wondered if there was anyway of sticking it back together maybe?
My fender had a crack roughly 2"x2" I took a heat gun to the underside of the fender. Be careful not to go crazy with the heat or the plastic will discolor. After the plastic was soft I took a butter knife and spread the melt across the cracks fusing them. Slapped a sticker on the other side and you can't even see the damage. The repair has held for over three years.
Thanks Charlie! It does look like a soapbar in the avatar. It's just the nickel pickup cover. I swapped out the stock pups for some Seymor Duncan '59s.
My freinds tele has a seymour duncan in the neck, its so smooth, and even sounding its just amazing. Shame about the huge neck, and boring appearance...
Funny how ya'll changed the thread from a fender to a Gibson!
yeah , nice guitar , no doubt about it but if you want to talk about guitars go do it somewhere else and not in my mudguard thread ta very much :hl:
That would be english for thanks. Although you won't find it in Websters.
