September 23, 20179 yr Author Hoodie 2, i'll send you a message with the dealers details. Edited September 24, 20179 yr by chappo
September 24, 20179 yr 2 hours ago, oni nou said: The information you asked for about is it in or out has already been given here.......I sense another ceelo video coming from b40rt. ?. (Unless its an Amal)
September 24, 20179 yr These carbs are basically the same used on all the small 4 strokes for the last 30 plus years. You just are not used to this adjustment being there as they come plugged or capped. (due to emission standards) They are on 4 wheelers, three wheelers and motorcycles. They are fuel screws. You can never go by an owners manual as things are lost in translation. In is lean, out is more fuel. PS You did not move the fuel valve to prime? Edited September 24, 20179 yr by lineaway
September 24, 20179 yr 8 hours ago, lineaway said: These carbs are basically the same used on all the small 4 strokes for the last 30 plus years. You just are not used to this adjustment being there as they come plugged or capped. (due to emission standards) They are on 4 wheelers, three wheelers and motorcycles. They are fuel screws. You can never go by an owners manual as things are lost in translation. In is lean, out is more fuel. PS You did not move the fuel valve to prime? OK, you guys are convincing me. I'll get the carb out again (PITA) and wind it out another half-turn. See if that does it. If it does richen it, it might run a bit cooler as well. PS I run the fuel tap on the solenoid setting and only open it manually when I need to top up the carb before starting. I am slightly suspicious that it leaks a bit as the garage continually smells of petrol, but I need to do some more investigation there.
September 24, 20179 yr I don’t know abut the carb in this application, but I’ve used this tool on many bikes to successfully adjust the pilot screw. https://www.motionpro.com/product/08-0119
September 26, 20179 yr Author Thanks for all the help guys , had a 'tweek' yesterday and she's running nice and clean at two turns out with the Jitsie FUEL screw. What also didn't help during all this was that she was running hot due to a poor electrical connection that was causing the fan to run at half speed. The connection was one of the many above the top of the carb shock absorber area, only noticed it when I cleaned the air filter. ( noticed the slow running fan when cleaning her off after the trial ).
October 8, 20179 yr On 21/09/2017 at 10:42 PM, 4stroke said: Turned the mixture screw out half a turn. I've done that and it worked for me too.
October 10, 20178 yr I fitted one of the first Jitse adjusters and the tip broke off in the carb - check for this!
