lotus54 Posted October 30, 2017 Share Posted October 30, 2017 I dind’t really see this addressed yet. I just picked up a 2016 300 Factory 4T and I’m fitting the long range tank I got from someone. The instructions I’ve seen are all for the 2-stroke, the fuel line seems to have a bit of an off routing. Anyone here mounted one and how did you run it? thanks Mark Quote Link to comment Share on other sites More sharing options...
reggie Posted October 30, 2017 Share Posted October 30, 2017 I find it best to run the fuel line outboard of the frame. This way it is quick to change from trial mode to trail mode. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted October 30, 2017 Author Share Posted October 30, 2017 1 hour ago, reggie said: I find it best to run the fuel line outboard of the frame. This way it is quick to change from trial mode to trail mode. Thanks- that makes sense. Did you run it on the left side then? Quote Link to comment Share on other sites More sharing options...
markbxr400 Posted November 2, 2017 Share Posted November 2, 2017 I don't hook mine up at all, so didn't tap the main fuel line. I carry a small gatorade bottle to transfer fuel when needed. Makes it easy to take the tank/seat off even out on the trail if I want it out of the way. The PO of my bike passed along this tip when I bought the bike. Said he had a case where the routing of the lines caused it to burn or rub through. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted November 2, 2017 Author Share Posted November 2, 2017 I routed it on the right side (outside frame) and over the carb. It seems to work well. I can see not hooking it up- I tried just turning it off to have a big reserve. But perhaps I’ll put on a switch to turn off the main petcock- keeping the original tank as reserve. thanks for the idea. mark Quote Link to comment Share on other sites More sharing options...
billyt Posted November 2, 2017 Share Posted November 2, 2017 Mark. Another option is to install another Beta fuel solinoid from the auxiliary tank into the main system, Quote Link to comment Share on other sites More sharing options...
jm_ Posted November 2, 2017 Share Posted November 2, 2017 Hello, I have connected the auxiliary line directly to the breather line of the main reservoir. So, as the gasoline is used in the main, it is sucked (?) from the auxiliary. And the line runs below the auxiliary tank. The same system is used in the Hebo tanks behind headlight. Cheers, JM 1 Quote Link to comment Share on other sites More sharing options...
v1nn1e Posted March 27, 2018 Share Posted March 27, 2018 (edited) Not got a Beta yet but interested in this option. Is it feasible to use this seat/tank unit to road ride a short distance to a trial, then remove it for the trial, and re-fit to ride home again? Might influence my decision on what bikes I start to look at Thanks Edited March 27, 2018 by v1nn1e Quote Link to comment Share on other sites More sharing options...
markbxr400 Posted March 30, 2018 Share Posted March 30, 2018 On 3/27/2018 at 8:09 AM, v1nn1e said: Not got a Beta yet but interested in this option. Is it feasible to use this seat/tank unit to road ride a short distance to a trial, then remove it for the trial, and re-fit to ride home again? Might influence my decision on what bikes I start to look at Thanks Yes, look at my earlier post. Pops on and off with simple removal of the bolls and rubber band, and no fuel lines to fool with. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 30, 2018 Share Posted March 30, 2018 I don't suppose you'd get away with a GTX can slung from the belt of your jacket as we used to do, but a proper petrol container in a backpack seems a better way to do it. Gives you more choice of bike if nothing else. Quote Link to comment Share on other sites More sharing options...
v1nn1e Posted March 30, 2018 Share Posted March 30, 2018 Yes, I've seen a 2 litre plastic container on eBay that looks back pack sized. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 30, 2018 Share Posted March 30, 2018 I got one of those but it needs a small diameter funnel to fill it. They're also available with a full size orifice so look carefully. Quote Link to comment Share on other sites More sharing options...
markbxr400 Posted March 31, 2018 Share Posted March 31, 2018 Or get the Long Range kit and at least have some semblance of a seat to get where you want to ride trials (+ have some gas when you get there). Love my Long Range Seat . . . 1 Quote Link to comment Share on other sites More sharing options...
austin6728 Posted August 16, 2019 Share Posted August 16, 2019 Just bought a long range tank/seat for my 2018 Beta Evo wasn't to sure about it at first took a little bit of fiddling to get it to sit right and the instructions were in Italian which never helped. It makes th bike look a bit odd and I've only used it the once so far but was pretty happy as I hardly noticed it was there when riding in the usual stand up trials position and was happy with the option to sit on my backside when riding along trails so far so good looking forward to exploring further afield with the extra fuel range ? 1 Quote Link to comment Share on other sites More sharing options...
