Milky oil
Went out yesterday and when I got to the venue I noticed my oil had gone milky, it wasn’t like that when I last rode it which was a couple of weeks ago, I’ve changed it yesterday and checked to water level and it’s fine, anyone got any ideas why it’s done it ?
  • Replies 32
  • Views 10.7k
Most Popular Posts
  • Turns out that clutch casing bolts where starting to come loose and letting water in the casing, it’s all sorted now
  • This is what I’ve got which will just stop there being an open pipe near where water can get in. can anyone also tell me that if my output seal was leaking would it be doing it all the time or ju
  • Old ossa part saves the day!
Obviously an leak in your coolant system, or you have held the high pressure washer a longer time to the oil fill plug which wasn't screwd tight?
In the picture, is that oil leaking from the site glass?
has the seal for the site glass is weeping, they will weep both ways when power washing.
I hope this is the simple, possible, problem.
good luck.
I think it's just water pooled outside the glass. It's a bit concave so it tends to sit there a little.
Milky oil is generally one of two things: you sucked in water via the filter (like, the bike was dropped in a river sort of deal), or you've got a coolant leak and it's mixing with the oil. It doesn't take much of a leak to make a mess of the oil, so you might not notice any loss of coolant until its been happening for a while, assuming that's what it is.
With the cold/warm/cold weather possibly condensation??- presume there is a breather open to atmosphere somewhere??
There is a breather pipe that ends up in the air box but I’m haven’t had chance to see where that comes from, and if your a bit gung ho with the pressure washer you do get water in the air box so it may be running down the breather pipe ? I also have a heater in the garage that’s timed to come on for a hour or so three times a week to dry boots but it’s also pointed at the bike which is kept under a pair of thick lined curtains so maybe it’s getting warm and then cold and that’s causing the condensation?
Water int'oil lad. A repeat event post oil change will not bode well. Coolant level ok ???. Greyish deposits sometimes result from alloy parts fretting.
For me, colder weather, hot engines being plunged into cold streams equals milky oil through condensation. I just live with it and change the oil more often.
I think I'm going to keep any eye on it, I have it on good authority that the water from
the cooling system cant get in to the gearbox oil so its either going in through the seal on
the out put shaft or down the breather in the airbox
What breather in the airbox? The only exit from the airbox I ever recall seeing on mine was the water drain, which is just a plastic check valve like you find in every other bike's airbox that allows water out. But it doesn't go anywhere other than onto whatever is under the plug.
In fact, thinking on it a bit more, I had the entire airbox out of mine regularly when changing the plug and whatnot, and there was no connection from the bike to the airbox other than the air filter > intake interface, and some electrical connections.
Edited by heffergm
on my 2017 bike the gearbox breather pipe ends up inside the airbox on the
left as you stood on the bike near the sensor thats in there as per the attached photo
so there is a small chance of water traveling back down the breather into the gearbox
Is yours an '18? That'd be a difference from the '17.
I will tell you this: that section of the airbox tends to fill with water, especially if you wash the bike and spray towards the airbox intake. Also, as I found out once, if you've got the bike in a truck bed/trailer and you're transporting it in the rain.
mine is a 2017 Fajardo replica so i would pressume it has some 2018 items on it
i try always stuff a cloth in the air intake whilst I'm washing it off but even with
that in and trying to avoid the area I still have to have a mop up in there, good job
its a 10 second job to get in there. I'm thinking of fitting a one way valve like people
have to vent there petrol tanks as I have a couple kicking about the garage
