January 2, 20188 yr Narrow yokes? Are we referring to what are also called triple clamps? Narrow vs wide, does this deal primarily with how the front flexes when the bars are turned? Or is there more to it than that?
January 2, 20188 yr Of the bikes on the list I have a Bultaco 199a and a Ty250a and have been able to ride a KT250 and TL125 in sections. For me the TY is the easiest to ride confidently,but I have pretty limited skills and practice time.
January 2, 20188 yr 3 hours ago, pmk said: Narrow yokes? Are we referring to what are also called triple clamps? Narrow vs wide, does this deal primarily with how the front flexes when the bars are turned? Or is there more to it than that? Yes also called triple clamps. I think there is something about flex /leverage / deflection which isn't helped by a narrow triple clamp. Nobody copied it , let's put it that way Edited January 2, 20188 yr by baldilocks
January 2, 20188 yr 8 hours ago, baldilocks said: @nigel dabster the 242 yokes were different again and I think the 242 was a much better all round bike. Similar power to 240 Fantic but it didn't stall as easy. Funny that as I hate montesas, but gainst my better judgement I bought a 242 and its a cracking bike, and as good in standard form as any 200 fantic if not a better motor. Im sure its the best under rated twinshock out there.
January 2, 20188 yr Well when the 242 came out my dad didn't sell Fantic. We did take 240 Fantics in part ex against new 242s. The montesa was thought to grip better. Personally I thought the Fantic forks, gearbox and clutch were better but as an all round package the mont certainly held its own.
January 3, 20188 yr So with all the ideas posted so far, is there any magic set of angles for steering head angle that works better than others. i openly admit never riding most of those bikes. I do find the MAR turns well, but does sometimes tend to try and tuck the front wheel in a tight turn.When this happens, things kind of stop rolling and the front tire slides unless you straighten the bars a bit. Almost feels as if there is too much offset in the triple clamps. Edited January 3, 20188 yr by pmk
January 3, 20188 yr What you have described is an indication that the trail dimension is currently less than ideal. You can increase the trail by lowering the rear of the bike or raising the front, or both. It can also be increased by reducing the offset as you have said. Riding technique also has a big effect on what you are experiencing. For the front end to work properly in tight turns on many twinshocks, the bike needs to be leaned towards the inside of the turn (probably a lot more than you think is normal) and the rider's weight should be on the outside footpeg.
January 10, 20188 yr My choice would be the Fantic 240 assuming all are stock standard as new. But a huge amount can be done to stuff up the handling or improve it with ride height, shock/ springs etc, as we all know. You can make a pig into something that goes really well, with a bit of knowledge. The pigger it is, the more you will have to do. I made a KT250 go quite well. Took a lot of work. Still got to work on the front forks, (still standard). If I didn't have to work on it, It would take half the fun away
October 16, 20188 yr On 10/01/2018 at 2:48 AM, still trying said: My choice would be the Fantic 240 assuming all are stock standard as new. But a huge amount can be done to stuff up the handling or improve it with ride height, shock/ springs etc, as we all know. You can make a pig into something that goes really well, with a bit of knowledge. The pigger it is, the more you will have to do. I made a KT250 go quite well. Took a lot of work. Still got to work on the front forks, (still standard). If I didn't have to work on it, It would take half the fun away have you tried a 242?
May 6, 20206 yr I have a one off TL 125 frame and I am thinking of installing an adjustable head set like the old boyd and stellings units. It would seem to be hugely adjustable -- but maybe more confusing. Have any of you seen this? Pete Edited May 6, 20206 yr by pinsx3 forgot picture
