July 9, 20188 yr MT43’s do have a very stiff side wall. Could be a factor on coming off a rim for sure. How hard he rides it might also be a factor. Good luck.
July 10, 20188 yr 12 hours ago, motovita said: The 250 pound motorcycle is likely a factor. I think the MT43 may have stiffer sidewalls than the Pirellis you used in the old days. The model tire you are talking about is as old as the Aprilia. But that is not the old days! I still have some brand new ones from the seventies!
July 10, 20188 yr Whilst on the subject of decent Trials tyres, I'm looking for a 3.50x18 (no idea what that converts to in new sizing).............Have found one on ebay, not a known make a far as I know, and I guess at a push it will do the job, - but ? Cannot go 400x18 as it rubs on swing arm Bike is a 70's 123 cota, which originally had 17" rear wheel............ Anyone any idea's ?
July 10, 20188 yr Maybe a Shinko as they are a strange shaped tire. SR 241 series. Edited July 10, 20188 yr by lineaway
July 10, 20188 yr 1 hour ago, lineaway said: Maybe a Shinko as they are a strange shaped tire. SR 241 series. Cheers, mate.
July 10, 20188 yr 6 hours ago, Twinshockandy said: Whilst on the subject of decent Trials tyres, I'm looking for a 3.50x18 (no idea what that converts to in new sizing).............Have found one on ebay, not a known make a far as I know, and I guess at a push it will do the job, - but ? Cannot go 400x18 as it rubs on swing arm Bike is a 70's 123 cota, which originally had 17" rear wheel............ Anyone any idea's ? I've seen them here in the USA using inexpensive dual sport tires, Shinko, Kenda, etc. Whatever fits and has a vaguely Trialsy tread pattern.
July 10, 20188 yr 5 minutes ago, motovita said: I've seen them here in the USA using inexpensive dual sport tires, Shinko, Kenda, etc. Whatever fits and has a vaguely Trialsy tread pattern. Thanks motovita, might have to go down that route here in the uk.
July 10, 20188 yr a - most tech data sheets will say something like no tubeless tyre is designed to go below 6 psi (and not risk the chance of rim failure) - now that's not how we all use them but that's what the small print says ... b - all proper trials tyres are 400x18, except the x lights (made in metric @ 120/100/18). you should be able to get trial pattern tyres from mitas, cheng shin and maybe some others but they won't be a trials like (compound, etc) as the rest
July 11, 20188 yr 14 hours ago, rabie said: a - most tech data sheets will say something like no tubeless tyre is designed to go below 6 psi (and not risk the chance of rim failure) - now that's not how we all use them but that's what the small print says ... b - all proper trials tyres are 400x18, except the x lights (made in metric @ 120/100/18). you should be able to get trial pattern tyres from mitas, cheng shin and maybe some others but they won't be a trials like (compound, etc) as the rest Hi Rabie, the tubless issue would not be a problem, as I run tubes;
