‘18 popping out of gear
  • Replies 155
  • Views 53.7k
Most Popular Posts
  • wheelieman14
    wheelieman14
    My 2015 Evo 200 seems harder to find neutral & I sometimes need to resort to using my hand to find the delicate notch between 1st & 2nd gear. I think it might have something to do with using s
  • I've got a 2019 been out a few times on it and today it came out of 2nd on its own a few times....after coming off an 06 that was absolutely bullet proof i'm starting to wish i'd tried a different bra
  • dan williams
    dan williams
    Rode yesterday. It’s good. Bike shifts easily. Stays in gear. Is still a pain to find neutral but no worse than stock. I think I’m done. ?
My 18s popped out of second 3 or 4 times since I’ve had it only in the last month not the first 6 weeks I had it. My 16 used to do it regular and was one of the reasons I got rid.
Same as mine. Was awesome to start with. Now I’m slightly spooked. It’ll be a few weeks before I get the rest of the parts to try the cam follower with the smaller bearing but I’ll post once I get it all together.
Also noticed from the very first oil change there’s a lot of swarf on the sump plug with regular changes aswell
My new to me Evo jumped out of gear twice last night, pretty frustrating.
I'll be following along.
  • 3 weeks later...
Cam follower arm with pin. First attempt at press fit and stake with punch to see if it’s reliable. Now to abuse it and see if I can pull the pin out. Is it reliable enough to put a bearing on? We’ll see. (edit) Nope, bearing pin too short for my comfort. Pulled out way too easy. Back to the drawing board and a longer pin that can be mashed with a press.
And a clutch holder tool. I love emachineshop. Couple hours on the computer, wait a week and custom tools appear!
Edited by dan williams
Status update
Well so far I've just done the indexer so maybe that plus the new cam will work. I'm waiting on a new version of the bearing pin so it'll be a few weeks before I can try it out. I may whine but it is fun to tinker with this stuff.
C'mon Dan, I think the rabbit's out of the hat, you do R&D for Beta !!!!!!!!
Guy
Guy
Shows all the factory bosses and top tech guys are fans of Trials Central and read of all the developments going on in sheds and garages and then stick them on the  following years bikes :D:P
