Hi looking for a little help setting gas gas chain
Hi people new to the trials world had a bike a few mnths now been on a two times since owned.only short rides.
What I've noticed is when pushing the bike or no weight on the bike the chain rattles on the frame underneith the front sprocket. Is this normal?
Setting the chain I have the bike raised off the floor swing arm at lowest.both nuts on rear wheel undone.turn the adjusters so marks are same both side and have the tensioner about a thumbs space away from swing arm.lower the bike down push it and the chain rattles
  • Replies 61
  • Views 14.6k
Touching the frame means its way too loose or also too tight, yet judging by the chain tensioner it seems correct :lol:
This could be ok, as it sounds like you are missing a piece of rubber on the frame which it runs on
Edited by faussy
Is it because am spinning the wheel with no weight on the bike.what's the bit of rubber I'm missing I've taken a pic of the chain over the frame at the bottom.
When you're riding it probably wont touch so should be ok. Try and reduce the amount of pushing you do !!! ie keep your feet on the pegs
Lol obviously but when bike leaves the ground and wheels turns chain makes horrible noise.
Been looking to see if the frame should have a chain guide on it so far not looking like should. The later ones have I seen on Google images just struggling to find a picture of a bike my year around the sprocket.
like now on stand turn back wheel chain rattles on frame realy loud this could be normal an I'm being paranoid. I would of thought the tensioner should keep it lifted off frame.as mentioned completely new to me.
Your tensioner looks ok but you are missing the rubber pad that the chain slides over the frame. The part No is BT280212026
Dnt think the 04 pro as the rubber bit ya mention mate as it's not listed in the parts manual and Google says that's 2013 onwards mine is 2004.
Any one have a picture of there 2004 model were the frame and front sprocket are see if there's have the rubber chain guide
2 hours ago, Trials madness said:
Mine is as follows
That gearbox sprocket is worn out and needs replacing, that probably means the chain is knackered (technical term that) as well. I’m wondering what the rear sprocket teeth are like too!
My tensioner is set this far off swing arm.
Chain is rubbing against the tensioner arm, this needs to be corrected. When you push the bike the chain is not under any tension apart from the tensioner arm if the chain has been set properly in the first place. When the bike is being driven by the engine the chain will be pulled tight along the top run and clear the frame, except when the suspension is being compressed or on rebound, then the chain will hit parts of the frame ie the swing arm...hence the protectors....it’s not a precise science.
Chain was rubbing on tensioner when purchased the bike as had slight bend. since as been.straightened.
The 04 parts manual doesn't list any frame rubber chain guide they seem to be 2013 models that have the rubber guide hence protectors
Edited by Trials madness
