2 stroke oil facts & myths
" Fully synthetic is fine for modern motors, not for our 50 year old ones. I think I have tried most, but have settled on Lucas semi sync. At around 32 to 1, that is 187 cc to 6 litres of fuel.  I may be right, or wrong, but my motors run just fine at that. "
This statement was posted in another forum, I asked for some evidence, or even a hair brained explanation, nothing !!
I'm not sure the o p actually rides at all, who mixes up 6 litres of 2 stroke ?  Is that overfilling a 5L can, or part filling a 10L can  ?
Anybody care to comment ?
Edited by b40rt
  • Replies 42
  • Views 14.6k
Most Popular Posts
  • It's been my experience that back in the 70's & 80's using leaded fuel and ratios of 25-30/ 1 there was very little build up of muck in the exhaust and basically no deposits on top of the piston o
  • Aspen fuel is sold in plastic cans, has a 5 year shelf life.  As for the oil question,my standard response is - "Oil is better than no oil"
  • I only put 15L in my 20L can. What do u think of that.
What do u think of that.:bouncy:
6 litre cans are a popular size. Not as common as 5, but pretty common nonetheless
£6 or £7 for a 5L.  £40 for a 6L, makes perfect sense !
Whats price got to do with? They are made by numerous manufacturers and are a far superior can. You obviously have never used one seeing that you didn't even know they existed. They are rather common with the gardening and landscaping fraternity. Just because it doesn't make sense to you doesn't mean it doesn't make sense.
Edited by faussy
Have you anything relevant to the topic to add ?  ( I think your last line should read "just because it doesn't make sense, it doesn't make sense )
Silkolene recommended I use semisynthetic in air cooled 70's motor when I asked their advice.  Various ratios suggested according to terrain/use but 50:1 for what we do.  Works fine with no sign of excessive smoke.
Are these  5-6L cans plastic or metal .Because petrol starts to loose its kick if kept in a plastic can for more than a week ,but in a metal can it stays fresh.
Why only semisynthetic ?
FWIW i was told by the Motul rep ages ago that full synthetic in a trials bike doesnt burn away in the silencer because the motor doesnt get hot enough like a moto crosser or race bike so they recommended semi synthetic. Actually they recommended their "scooter oil". I've used semi synthetic ever since with no problem but i am sure many will disagree. Always a horny subject this with so many different "recommendations". As long as the user is happy then thats as good a result as you can hope for.
Anyone confirm this?
Plastic tanks definitely are semi porous, so I can see there being some validity to this. Ambient conditions will obviously be a factor.
Edited by b40rt
Thanks otf, so depending where you compete will make a difference, 4 times round a field, or more traditional trials with long climbs that get some heat into the engine.
