Spark Plug Reach
Any cleaver person out there know if an NGK BPR5E is available in short reach ( ie12mm )
Thanks
BPR5HS looks correct ?
Edited by b40rt
1 minute ago, moleman said:
Change the E to H= BPR5H
Hi Craig, think the "S" only refers to the core being copper ?
Used to , probably still does , time moves on .
i would lose the R ( resistor ) and try a plug with an iridium or whatever is fashionable now centre electrode if it’s going on something with older ignition .
If you do a plug chop , don’t use a cleaver!  ( first post )
Does what it’s going in have a very good ignition system ?
E=3/4 reach, H=1/2 reach.  S is standard electrode ie. the fat type, different last letter refers to shape of the electrode tip
Thanks
 Yes but the top will hit the tank. LOL
