txt pro 280 clutch vibrations
Hi,
I have a gas gas txt pro racing 2013.
When a engage the clutch it starts vibratin. You can feel it in your backwheel. Clutch feels good no drag of weird sounds. Finger height is good anyone any ideas?
I use putoline light gear oil!
Greetz Clanned
4 hours ago, lineaway said:
 I would start with a M/C rebuild kit. Cheap, it couldn`t hurt to freshen it up. Those years were not so good for the M/C.
M/C rebuilt kit?
The bike has already new piston and crank bearings
Are the clutch plates fitted in the right order?
2 hours ago, Clanned said:
M/C rebuilt kit?
Clutch Master Cylinder
iT'LL BE INCONSITENT PLATE THICKNESSES. IF YOUVE PUT IT BACK TOGETHER NOT EXAC TLY AS BEFORE THIS CAN HAPPEN. TWO OPTIONS STRIP IT AND RE ALIGN(DIFFICULT) OR LIVE WITH IT FOR A WEEK OR TWO, HAMMER THE CLUTCH AND IT SHOULD REBED AND START FEELING BETTER. Caps lock was on . Not retyping !!!
Oke thanks  give it a try!
  • 3 months later...
I order a new set of plates and the problem is gone thanks for the help!
