March 29, 20206 yr I scored a BSA Victor with a B250 motor and figured I would build a trials bike out of it. I brought the head angle in, brought down the upper shock mounts etc. i am up to the point to set steering stops. My forks (old betor) have 70mm offset and my tank is really narrow. Would 90* be a good point to set stops? I can make thicker bumpers later. thanks. Frank
March 29, 20206 yr If you want to read about bike geometry, steering head angles,swing arm angles, etc, go to, "Trials Australia", then; forums; next "Twinshock and classic trials", next, scroll down to, "Steer clear, understanding steering". Its really useful. Great looking project by the way, Good luck Edited March 29, 20206 yr by still trying alter text
March 30, 20206 yr Author Thanks for a quick reply but I am looking for help setting up the steering stops and would like to know how many degrees to allow the handlebars to rotate. Thanks.
March 30, 20206 yr 3 minutes ago, Ftwelder said: Thanks for a quick reply but I am looking for help setting up the steering stops and would like to know how many degrees to allow the handlebars to rotate. Thanks. Just set the stops so the forks don't damage the tank or whatever, you can't have too much lock.
March 30, 20206 yr 58 minutes ago, Ftwelder said: Thanks for a quick reply but I am looking for help setting up the steering stops and would like to know how many degrees to allow the handlebars to rotate. Thanks. 90 degrees is an awesome design target. If you've got it, flaunt it. I'd love to see a photo.
March 31, 20206 yr Author On 3/30/2020 at 6:52 AM, feetupfun said: 90 degrees is an awesome design target. If you've got it, flaunt it. I'd love to see a photo. It looks like I am just short of 90 degrees. It’s my first fuel tank build so I am reluctant to attempt an alteration before welding. I’ll set the stops a little short and let nature do it’s thing haha Edited March 31, 20206 yr by Ftwelder
April 1, 20206 yr For comparison, this is a standard Kawasaki KT250 front end. I chose this photo because this bike has the most steering angle of any of my bikes.
April 1, 20206 yr 90 deg of lock won’t do you any good as none of the tractive effort of your back wheel will be rolling the front. It will all be trying to skid the tyre sideways. Feetupfun’s photo could be a good guide, or measure any modern trials bike. Maybe you could weld on two threaded bosses and then insert a bolt in each as a lock stop. That way you could do a bit of testing before finalising.
April 1, 20206 yr 90 deg wont work in practice for the reason Trapezeartist mentioned. Two threaded bosses are the way to go. In the real world you very rarely use full lock as you run the risk of the front end tucking under. I would not exceed 80 deg but would also fit threaded bosses. M6 is fine angled so that the head of the bolt, I use allen bolts but choice is free, contacts the yoke at 90 deg.
April 1, 20206 yr 14 hours ago, feetupfun said: For comparison, this is a standard Kawasaki KT250 front end. I chose this photo because this bike has the most steering angle of any of my bikes. Mine
April 1, 20206 yr Author Agreed, something between the BSA and the KT looks right. I appreciate the advice, thanks! Frank
April 2, 20206 yr 10 hours ago, Ftwelder said: Agreed, something between the BSA and the KT looks right. I appreciate the advice, thanks! Frank Just leave yourself enough adjustment for when you eventually discover your wrong.
April 2, 20206 yr Author 13 hours ago, b40rt said: Just leave yourself enough adjustment for when you eventually discover your wrong. 13 hours ago, b40rt said: Just leave yourself enough adjustment for when you eventually discover your wrong. Thankfully I picked up on the fact that flexibility in design is pretty important. A good example is foot peg location. Originally I used Michael Wallers Youtube advice regarding positioning and was going to weld on tubular brackets but went back and designed new peg mounts that attach at swing arm pivot. My fork offset is 70mm and all at the crown/yoke/triple clamp so bolts are a great idea. When I changed the head angle I made an extra large diameter head tube and could potentially make adapter cups that alter head angle. Since I have your attention, should I make the swing arm as short as possible? The adjustment will be at rear axle. Thanks for the advice. Frank
April 3, 20206 yr Generally a trials swingarm should be as long as possible yet still achieve the wheelbase that you want. For a bike with something like your B250 engine (an engine that is long from front to back) you will probably end up with as short a swingarm as will fit an 18" trials tyre and the wheelbase will still be on the long side of ideal. Edited April 3, 20206 yr by feetupfun
