brianjonesphoto Posted December 27, 2020 Share Posted December 27, 2020 I dove into my winter maintenance today on my 05 4rt. I went to change the fork oil and noticed the spring leg was binding mid stroke. After I tore the fork down I found a small ridge from a dent in the lower slider. I know the proper course of action is to replace the slider. I’m not sure I can get the part. One online source says available in 2-3 days another says extended back order due to covid and no sort of timeframe. I’m in the US so it will likely me harder to find one. if I can’t get a replacement what are my options? I had the thought of using and exhaust pipe expander with hose clamps on the outside to support the leg to hopefully push the dent out enough without deforming the tube any further. im hoping I can get some options from my suspension guy on Monday. thanks. Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted December 27, 2020 Share Posted December 27, 2020 (edited) Reeming tool welded onto an extension bar to get down in? It wouldn't weaken it that much. Edited December 27, 2020 by jonboy883 2 Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 27, 2020 Share Posted December 27, 2020 (edited) As above, but have the fork welded first to fill in the dent. Edited December 27, 2020 by b40rt 1 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted December 27, 2020 Share Posted December 27, 2020 (edited) I had a similar problem with an RL Suzuki, which had rather thin sliders, but the fork jammed completely (the Mamore Road, not to mention the sections, was fairly interesting with a solid front end?). I can't recall exactly what they did but a local machine shop were able to sort it and it lasted for years thereafter. Edited December 27, 2020 by 2stroke4stroke Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted December 27, 2020 Share Posted December 27, 2020 (edited) 3 hours ago, jonboy883 said: Reeming tool welded onto an extension bar to get down in? It wouldn't weaken it that much. I've done similar on a few sliders, but I used a boring bar in a lathe. Edited December 27, 2020 by suzuki250 Quote Link to comment Share on other sites More sharing options...
mcman56 Posted December 27, 2020 Share Posted December 27, 2020 4 hours ago, suzuki250 said: I've done similar on a few sliders, but I used a boring bar in a lathe. I have been wondering about this. How do you set up a slider in a lathe? All of the external surfaces are non-precision as-cast surfaces. How is the slider held and how do you get the bore aligned straight and centered? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted December 27, 2020 Share Posted December 27, 2020 (edited) If you can't get it sorted with a reeming tool setup to you might check Banyeres. Might be worth considering: https://jbanyeres.com/en/suspension/2440-suspension-botella-original-showa-conjunto-derecha-izquierda.html?search_query=showa&results=83 And the other option might be a full set: https://jbanyeres.com/en/montesa/471-horquilla-delantera-showa-trial-modelo-2009-2012-39-mm.html?search_query=showa&results=83 Edited December 27, 2020 by jonnyc21 Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted December 28, 2020 Share Posted December 28, 2020 18 hours ago, mcman56 said: I have been wondering about this. How do you set up a slider in a lathe? All of the external surfaces are non-precision as-cast surfaces. How is the slider held and how do you get the bore aligned straight and centered? there are a couple of ways, In a four jaw chuck and a fixed steady (and a bush to fitted to run the steady) or the slider mounted on on the cross slide (vee blocks and lots of packing), and boring bar in the chuck both methods take a lot of clocking up! 1 Quote Link to comment Share on other sites More sharing options...
