February 21, 200620 yr Question, First modern trials bike 05 280 txt pro , and i noticed that when i put the bike in neutral while it was running, which was difficult to find most of the time ?? (usual thing !?) The gearbox seemed to make a noise, if i pulled the clutch in it went away, no change if i leant the bike either way. I only noticed it halfway through first day of riding it, Is this normal ? i know some road bikes have noisy clutchs (honda hornet 600) But im alittle concerned. Killed the bike, found neutral again ,and it stopped, tried it later and made no difference cheers Mat Edited February 21, 200620 yr by Magicmat
February 21, 200620 yr Don't know about the noise but it should be harder to find neutral with the engine running than without, this is so you're not going into neutral accidentally when riding.
February 21, 200620 yr Author i can get it with my hand, and yes its easier with the engine turned off, But the noise as if it just nearly in gear, (when in neutral) seemed strange, just wondered if anyone else had noticed ? Mat
February 21, 200620 yr hey my 05 300 txt pro makes a different noise when its in neutral never realy bothered me though cause my bikes hardly ever in neutral to notice
February 21, 200620 yr Mines the same mate i was told by a dealer if they dont make that rattly noise when not in gear then theres something wrong.
February 21, 200620 yr Author Good !! was slightly worried, as long as im not taking teeth off gears or summat then its all good !!
February 21, 200620 yr i got a 04 280pro at the weekend and mines the same! does yours make a noise wen u got into 5th?
February 21, 200620 yr Author the final page is alittle confusing, "higher than specified...then shim" do they not mean that if your clutch is smaller than specified then shim with a new plate ? Im abit lost r2w, sorry ---also rising sun, say not to use synthetic, GB/trans oil, but the 05 manual says TO use synthetic GRO oil ?? ---Conflict of opinion there?? Edited February 21, 200620 yr by Magicmat
February 21, 200620 yr i got a 04 280pro at the weekend and mines the same! does yours make a noise wen u got into 5th? <{POST_SNAPBACK}> Mine does sounds like a clunk/scrape but ive noticed that 5th and 6th are totally different gears road use obviously.
February 21, 200620 yr Author 5th and 6th are well different, i havnt noticed it but only ridden for 4.5 hrs so far, i used 5+6th to beat my little bro on his mini moto, He thought he was all-that but i showed him !!
February 21, 200620 yr the final page is alittle confusing,"higher than specified...then shim" do they not mean that if your clutch is smaller than specified then shim with a new plate ? Im abit lost r2w, sorry ---also rising sun, say not to use synthetic, GB/trans oil, but the 05 manual says TO use synthetic GRO oil ?? ---Conflict of opinion there?? <{POST_SNAPBACK}> With regard to the "shimming" it has to do with the clutch pack thickness and the nature of the pressure plate style clutch. If you clutch is engaging where you want it, don't worry about it. The noise is totally normal and as r2 said, has to do with the finger actuators for the pressure plate clutch system. It's just the way they work, nothing to be concerned with in the least. There are some conflicts with the manuals from time to time. I think the recommendations of the GRP oil is down to a sponsorship arrangement with the factory and their race teams. The bikes come from the factory with ATF (red oil)...and it's best to stick with this. Stick with the non-synthetic ATF and change it frequently. Buy it in 4L tubs and use it up. Clean oil is ALWAYS better than dirty oil, no matter how expensive the dirty oil is. I change my oil in my Pro no less than every second ride as an example.
February 21, 200620 yr Author Automatic transmisson fluid ? Any paticular grade ? i use that in the clutch of my old bultaco. You seriously change the oil every two goes? do you ride it hard ? seems slighly excessive, Not that i am critisizing in anyway
February 21, 200620 yr Magicmat, Both of my bikes did this. I found on the 03 that the clutch piston was not resting against the clutch release arms(springy fingers) so they were rattling around when the clutch was disengaged. I cured it by bleeding the clutch again. The 05 did this too and I found out the cltch bearing plate (pushes the springs)was the wrong way round and the collar was against the roller bearing instead of the flat.
February 21, 200620 yr Author And did this cure your problem ? Could this be whats making the noise on our bikes ?? Matt
