speshal
Hello Newbie Here :) Advice Needed
85 posts in this topic
I can take a photo of mine but it will have to wait until Monday though. I leave early tomorrow morning for the Queensland Classic, Twinshock and Air Cooled Mono Championships in Stanthorpe. I`m camping there and Saturday night they are forecasting -5 degrees celsius. Should be a great weekend though. Graham.
Share this post
Link to post
That's great, Thanks Graham. :D I'd be interested to see how you've done it. I have an idea of using the old bracket from the Femsa coil to hold the new one, I just have to work out how to get it apart.
Have fun in Stanthorpe!  It sounds like fun :D
1 person likes this
Share this post
Link to post
From memory I used a piece of aluminium flat bar which was bolted to the old coil mount, the bar extends forward towards the headstock, the new coil was then mounted off that.
2 people like this
Share this post
Link to post
Cheers for that 325, it gave me an idea.
I took the old coil bracket and mounted an L shape bar on to it.
Excuse the somewhat "agricultural" appearance, this picture was of a test fitting and using any old bolts that were lying around :D
2 people like this
Share this post
Link to post
It made a spark for the first time in 20+ years today :D
2 people like this
Share this post
Link to post
Hi, it's me back again.
I got spark and I had air going through the carb but the plug was always dry when I tried to kick it over so decided that the carb must be bunged up, It's got a Mikuni VM26-208 on it. The prospect of taking the carb apart scared the beejebus out of me - bits pinging out everywhere, losing stuff which I can't currently afford to replace but I found a few Youtube videos that demystified the voodoo surrounding carbs, so I took it apart, most of the videos I found were from Canada and to do with taking apart SnowMobile carbs but many of them mentioned that if you had a groove in the needle it was probably a good idea to replace it, so I was just wondering what you'd do if this was yours....?
Share this post
Link to post
Grooved float jet needle generally causes flooding. Most likely cause of no fuel getting to plug is gummed up pilot jet, if you're worried it doesn't cost that much to replace every jet in your carb
1 person likes this
Share this post
Link to post
Cheers for that Tony :D
I've pulled it all apart given everything a good clean with Carb cleaner, will see if that works.
Share this post
Link to post
After 26 years of sitting, neglected, in the garage............
IT STARTS!!!!! :) :):):):):):):):):):):):):):):):):):):)
Three things happened at that exact moment in time, a grown man had a little cry, the dog started barking and I deafened myself as I was in a relatively enclosed space with no exhaust pipe on it!
Thanks for everyone's help, expect many, many more stupid questions in this thread :)
5 people like this
Share this post
Link to post
Very done, and an interesting read. Thank you for your pictures and input.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
