- Past hour
Hello , i am 62 and did championchip trial last year for West- Flanders in Belgium and ended secont nationals....!!!, but i ride almost all my live...
Based in the West Midlands area. Will be doing a little poking around the area soon. Thanks, makes me feel better knowing I am not the only one that thinks growing up is optional, I was expecting many youngsters. I'm a little over 15st - or as I like to put it: 'I once had a six pack - now I'm older I can afford a barrel' I'm probably being harsh on myself, but was always fairly trim until I had the spinal injury which changed things being laid up so long. Came from a Speedway line from young, so bikes were in the blood. Still associate the smell of gunk with speedway bikes in my uncles garage.
Ukbta, welcome! I’m 64 and took up trials again three years ago after a 45 year gap. I’m not fat though but you make it sound like it’s fun. I may give it a try myself. Also, my friend from high school, just started up again too, and he is fat and is enjoying riding again immensely. We met up up in the Owyhee mountains in the Idaho desert just a month ago to relive old times. We had a great time! No, we’re not experts at all but it’s still a blast. Give it a go!
Welcome ukbta. Where do you live? You may find there's someone on here that is close to you. It will also help us guide you on questions like dealers, practice areas, etc.
Use a wall anchor and keep the bike as tight to the wall as possible. Keep the chain tight and as short as possible through a frame point and around the wall anchor. If you do it correctly, it should be as difficult to access as possible - even to lock and unlock. Keep an chains to ground anchors off the floor and tight, as that makes bolt croppers more difficult. A loose chain allows the cropper handles to be put on the floor and pressure applied to pop it, a tight chain means the croppers will need to be used with upper body strength alone, like an eighties Bullworker - star of many home video howlers. Good quality locks can be used to take the brunt of any attack. Abus do some good locks that are great for rear sprocket (discs not acccessible on most trials) - smart ones will notify you if they are activated, the Victory is just a PITA as it just spins - all of it, in all directions. All are grinder and impact resistant. A decent home chain is ideal, 16-22mm is best. Make sure it is hardened or tungsten carbide. Abus D Locks are tungsten carbide and both those and the victory/smart locks can be used with chains, making the chain alarmed. Kovix also do a similar set up with a cable designed as a 'quick' lock but will also work well with a smaller chain. The essential advice, is be creative - use as many locks as you can be bothered to unlock and DO NOT trust your garage doors - they are torn open in seconds! You can look into reinforcing up and overs, using frame dead bolts to prevent this, but there is olnly so much you can do. Asgard Security Sheds are getting pretty good now and as expandable, as we all knows bikes multiply in the night through no fault of our own.
Just wanted to introduce myself. Looking at getting a trials bike. Probably too old, too fat (that could be a franchise film with 200 sequels I am sure) but need to get fit and wasn't allowed one when I was a kid (Junior Kickstart for those oldies out there, might remember). Got back on a bike a few years ago after a long time learning to walk again post accident. Thought, what the hell - do it before the joints completely give out. I remember a friend that did MX, and there was always the old fat bloke at the back that was 65 and they all respected him and gave him space as he was having his fun and riding his own race. That will be me, no doubt. Work wise, I work with a charity in the motorcycle industry, so if you have any theft related issues - feel free to give me a poke and I will help where I can. Not had much to do with 2 strokes or trials bikes, but build plenty of road bikes in the past. Be prepared for many, many, stupid questions and head slapping moments.😁
ukbta joined the community
Ging502 started following 2022 EM epure race issue
Hello everyone, New EM owner here, picked up a used 22 epure race couple weeks ago. What a fun bike, been having a blast with it. Although I have one issue that I cant figure out, went through this forum and haven’t seen a similar issue. When riding the bike for a bit randomly it will start to hold revs sort of similar to if the TKO is turned on even tho it is not on. If I hold in the clutch and release the throttle the revs will very slowly come back down very similar to a lean condition on a ICE bike. But With no clutch engaged the bike does not pull or want to inch forward. It will do this in all 3 maps. Then after a little while of this if I pull the kill tether and reinstall it, the bike will just make the map switch tone over and over again non stop. I can change maps but the throttle will never come back to life. I can turn battery off and on and still the tone keeps going. I have to turn the battery off and let sit for 5-10 minutes and then it will start working normal again. I have done the recalibration deal of holding map switch for 10 seconds and the rear wheel spins 3 times but after its done the tone just keeps going. Im guessing it has to be a throttle issue? Its the domino throttle. The wires look fine, connection at the plug is good, wires dont pull tight when steering lock to lock, throttle housing isn't beat up and throttle tube turns nice and smooth and snaps back quickly. But im guessing it has to be something wrong with that throttle? Oh and bike is not equipped with the PRB lever. Just wanted to see if anyone has an opinion before I go spend $200 on a new throttle. Any help is much appreciated. Thanks
TRS Fan started following Beta EVO 200 Trials
Ging502 joined the community
@lemurIf the rims are anything like most TLR's i've seen the outside looks ok but the inside has become a sacrificial anode and just flakes away.
Yeah, The Sammy Miller number system was very basic.
Thanks Woody, that's very interesting. I had a feeling it could be a standard frame, it's good to have it confirmed. I presume somebody must have chromed it to make it look like a special.
I emailed Jitsie, and they responded that they hadn't had any problems with those springs. They asked me what year the bike was, and in the end, they brushed it aside, saying the spring wasn't suitable for my bike's year. I'm an amateur mechanic, and what I really enjoy is engine tuning. Back in the 1980s, I'd already tuned Vespa engines for racing, Puch Minicross engines with adapted Derbi cylinders, Puch Cobras manufacturing 6-stroke transfer cylinders... I have books from mechanical engineers on 2-stroke engine tuning, and also some MS-2 software for calculating reed valves, transfer case openings, and RPM, as well as calculations to determine carburetor diameters and some exhaust pipes, among others. What I mean by this is that I consider myself to have a minimum of mechanical knowledge, and I believe I know how to calculate BHP or RPM of an engine using mathematical formulas. I think that when I get a spring that they say is a clone of the original and it turns out the measurements don't match, I think I know how to perform the analysis and measurements to determine if it's good or not. You just have to look at the photos where it's clearly evident that they are not the same. I ordered the spring from a prestigious specialty store (they sponsor a private pilot in the World Championship), and they told me they didn't sell that spring because it didn't work. They sold the original. That's why I decided to order it directly from Jitsie. What I mean by this is that I don't like being treated like an idiot, and that my intention at all times is to give them information about the product they're selling, and that it's not what they say it is.
It's a 1972/73 Sherpa, the model number is 92. The frame/engine numbers are close because the UK importer used to sell them as 'kits' to avoid purchase tax, so when the bikes arrived from Spain with engine and frame numbers that matched, the importer removed engines and then sold a bike and engine to the customer as a 'kit'. It's a Bultaco frame, series 2 type 92, no idea why the top half looks chrome, the rear shock top mounts have been lowered to make them more angled. The tank is a UK made item as using the original Bultaco fibreglass tank on the road was illegal at the time as fibreglass tanks were outlawed, so UK bikes could have these fitted
Hugh would probably be able to answer your question. bultacoclassic.com
So, are you saying this is a standard frame which has been chromed?
92 SHERPA T 350 1972-1974 92.000.001
kevin2306 started following Barn find Sherpa, what is it?
What a belting find! not a clue on the info you are chasing but it will make a really good project! Kev
A funny thing happened over the weekend, I was on a green lane and as we slowed down at the end of the track an elderly chap came out of a house, flagged me down and asked if I'd like to buy a bike (like you do). Of course it's always impossible to resist and he took me into his shed and showed me a tatty old Sherpa which he said had been stored for the past couple of decades by his brother who had passeed away. The bereaved's family were going to put the bike in a skip but thankfully he stopped them doing that and rescued it. I'm not too well up on Sherpas and it's a bit of a mystery to me, the chap thinks it might be a Sammy Miller High Boy but I'm not so sure. The last High Boy I owned was a TL 185 version back in the 80s and my memory ain't what it used to be. Anybody any ideas what this is? The frame number, stamped on the head stock, is B 9203012 and the motor is M-9203037. The fact that the frame number is so close to the engine number makes me wonder whether somebody has simply chromed a Bultaco frame. The tank unit is alloy and it has what looks like an original Sammy Miller sticker stuck to the underside. There is also a large '3' stamped on the top tube. Anyway, I've bought it!.
Why don't you just re-anodize the original aluminum rims 🤔 there are lots of companies that specialize in aluminum anodizing.
I just did a quick search and found several, brand new items, for sale on eBay. https://www.ebay.com/itm/195646716202?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOoomOfjjk6J1qizlK-8piLtZ_ho3WY4UugHqZiuMB2HSxx7CbhGYXZQ&com_cvv=8fb3d522dc163aeadb66e08cd7450cbbdddc64c6cf2e8891f6d48747c6d56d2c https://www.ebay.com/itm/155406977666?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D290511%26meid%3D47427a76e5484a03a65637d71963318a%26pid%3D101875%26rk%3D1%26rkt%3D4%26sd%3D195646716202%26itm%3D155406977666%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimVIDwebV3WithCPCExpansionEmbeddingSearchQuerySemanticBroadMatchSingularityRecallWithVectorDbNsOptHotPlRecallCIICentroidCoviewCPCAutoWithCtrV3Enricher%26brand%3DUnbranded&_trksid=p2332490.c101875.m1851&itmprp=cksum%3A15540697766647427a76e5484a03a65637d71963318a|enc%3AAQAKAAABgAwqOHi2KCgf4%2F6SZSv1me4ebI%2FvqXEw%2FHB%2F8iWWqhXshqX5uohPx20BUGvMHd%2FNVdDC4KI%2FKTb49Rx8STjwMT6FumfvwgT%2BuVTaR3SZ3p348VRbA%2FTZNiAsQeTGoW59%2BW%2FUJrXmpr5hhWbI9yTw1RGQbyjxPcAqegqth%2FU5%2B%2FpivkqsLe%2FrQerAcD9BuwDR6wUgBHtodmc1uq7p424y098nMOnZ%2FJ8K74j6raS9IHQXxfk3oLhYC5pznElmVY2kZSpu%2FcQyGizieKX3ySAcpajhd2NwT62aErWxGjSWeAAoc46SYMDNF%2FLzMnEAyTdzr765pho6A7HFzPZ1oV5KOWEvsyRwPfli8gI9whhucHqiU9uj%2BP7ww30cq88jDN%2F2LwCBkLIodChQUzCHJMKsvC64kEXfpkEgwBsuv2VvHuV%2B6%2FC1nfkX%2BdhT7GTDKd%2FsNMu6s989A%2B09Uh0tIuKt7fEALjlgyNIlUCx%2BdO2AKGBY82h7goQ7RQGERQWoxvo8xQ%3D%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01K2WT68YK12EZBFAENM9MV0MB
ROB61 started following New Rim's.
I am new to this site and this is the first post. I am looking to Refurbish my Honda TLR 250, it has the original wheels still in. I would like to replace them with the Gold colour again , But unable to fined a supplier . If anyone can please send me some details of a retailer so I can start the rebuild I would be Very great Full.Thank Rob.
Well I took it to a trials park and it wouldn’t start again, despite fitting a new plug and fresh fuel. Even after a couple of attempted bumping starts on a nice grassy banking there was nothing (thankfully I took my other bike as well).
Electric Motion 2019 Trial – Bike Won’t Start
konrad replied to ManuMotion's topic in EM (Electric Motion)
As much as I'd like to help, it has never been my intention to give detailed troubleshooting instructions. There are a variety of reasons for this. You will probably need to fabricate the JST JWPF pick-off connectors described on my website. My advice is to find someone local who can assist you or perform the work.
By pre65wobbler
3 days and 15 minutes
