- Today
Millwoodva started following VIN Decoder
Just purchase this trials bike this evening and trying to figure out model by the VINVTRGG279801981041 It did start on first kick but was unable to ride it. Would only continue to fire on 1 sec intervals at wide open throttle with heavy smoke. So just.. pop..pop..pop.
Millwoodva joined the community
konrad started following EM 5.7 Retrofitted with Modern siliXcon SX Controller
The write-ups are quite technical, but maybe some here will be interested. This link is the actual retrofit process: https://www.electricmotiontech.com/home/em-5-7/sx-controller-retrofit This link describes some preliminary work to familiarize myself with the SX controller: https://www.electricmotiontech.com/home/em-5-7/sx-controller-experiments
The trials model definitely had superior suspension to the Explorer. But I think going forward, the Explorer will be a very desirable bike. I expect some trials models will get sacrificed to keep Explorers running. I'd suggest buying a ratty trials model to use as a donor.
Google BETA REV images then Google BETA EVO images and you will see the difference between the two types of frames the 4T has used. A 4RT is a HONDA montesa.
- 1 reply
- 1
Noel09 started following Beta 4t 2007 clutch question and What beta do i have?
Hi everyone, I know this seems like a stupid question but I just bought a 2007 beta 250 4-stroke and I'm trying to find out what exact model it's is? VIN is ZD3T3020070000206 . From what i can find its a rev 4T, but then I'm seeing evo's and 4RT's and rev3 4T, etc etc it's a bit confusing 🤡🤯 thanks
From memory the suspension was the same between the trials and the explorer variant. Marzocchi forks and Ohlins rear shock.
Hi everyone. Totally new to trials and Totally new to beta. I just bought a cheap and cheerfull 2007 rev4t 250 4-stroke. The clutch is dragging and it seems to then when driving it has to be let out completely then it engages kinda sharply. Anyway I found a few hints where you file the glue off the friction plates and polish the little dogs on the plates so I'll try that. But the lever is a bit sloppy and the screw that pushes the piston in the master cylinder is pushing at an angle? There's a small leak there too. Having a little trouble finding a master cylinder rebuild kit for it, hard to identify my master cylinder? Any tips appreciated. I'll add photos of master and of the parts that don't seem to line up.
Thanks for your response lemur. I live in France, but I'm a Brit ex-pat. I'm not sure I understand your comments. Why wouldn't you shop for used parts internationally and why wouldn't you buy used suspension parts? I've a long history of buying new and used stuff from all over the world, so I don't have an issue there. Why do you? Having parts in hand, even if they are worn or damaged is better than not having anything. Worn can be rebuilt and broken can be repaired... Thanks anyway. Cheers... Paul
What country do you live in? Guessing UK only because you called it breakers but used parts are not something you shop for internationally. Shocks and forks are not something I would buy used anywhere and you can buy those items new without needing to be OEM branded.
tinwelp started following TR280i parts search
Hello, I'm a noob to the forum, having just bought an Explorer. It needs some work, nothing dramatic, just fork seals and wheel bearings... oh, and a cylinder head to replace the cracked original... all which are in-hand. I've not ridden it much yet, but already it's a bit obvious the suspension lacks refinement. What I'd really like to do is replace everything with the TR280i kit, but parts seem almost as elusive as rocking-horse poop. Is anyone breaking a TR or have a shock and forks they're willing to part with? Thanks in advance. Cheers... Paul
tinwelp joined the community
I'm in ireland but they should ship
Thanks, loads of little jobs to do!
If you are UK based, BVM Moto have loads of spares and they are Beta dealers so should be able to hopefully get parts.
Fuel tap on your bike is a little strange and over-engineered as a result of being fitted with a carburetor instead of fuel injection, Wheel bearings only last a year or three at best. Fork seals wear quickly if the slide bushings are not set perfect, note that when you get new aftermarket slide bushings you might need to do some careful hand file work on the parts to make them fit well, I clean and dry fit the bushings to inspect for clearance, fit or stiction and then finish the assemble.
Ah thanks. I'm going to do all fluids and filters before riding. Looking to rebuild clutch master as it's dragging and leaking at master! Fork seals are leaking and front wheel bearings are gone. Looks like petrol is weeping from somewhere under tank. That tap on the tank looks to be broken or different from the manual too. Loads of little bits to do. Thanks for help.
Most rolling chassis parts and controls are very interchangeable between trials bikes, things like brakes, wheels and suspension assemblies are largely common between models and even manufacturers. We can almost tell you what all parts are going to regularly wear out and need replacement, wheel bearings linkage bearings, fork seals and slide bushings, brakes, levers, tires and chain. Most buy a spare air filter so you can always have one clean, oiled and ready to use. Tether kill switch is normally an add-on to trials bikes and a component that can often cause problems after some crashes. Being a 2007 model you should be replacing all fluids, brake fluid will be done by now if not already replaced.
Thanks lemur ill search jitsie
Add the word Jitsie to your search 👍
Noel09 started following Beta newbie
Hi everyone. I'm totally new to trials, and to fourms! . I just bought a 2007 rev 250 4-stroke. All I could afford at the moment. I'm just wondering where would be the best place to source parts? I can't seem to find anything on line. Every search seems to throw up parts for the 2504t RR )which I assume is a beta enduro bike)? Or the 2stroke trials, but not the 4stroke. I want to service it and do fork seals and replace a few bits etc. Thanks in advance Noel.
Noel09 joined the community
These boots are known to have a problem with the rubber inner top toe protector coming away from the boot when in use as it is not stitched just bonded , do not waste your time taking them back to the dealer if this happens just stick it back on with flexi type superglue gel.
PatT joined the community
It is the same as a 2010 model . It was fitted with cheapo tyres Pirelli MT43 that are not proper competition tyres, I think the rear shock was a OLLE the forks should be Marzocchi steel stanchioned forks as most 125cc pros had until the TECH forks appeared when Marzocchi went bust. go to www.thehellteam.com and search under Tech support GasGas info.
excess joined the community
So i found this bike for a good price I'm picking it up in a few days. It's going to be a spare bike so when buddies come to the house they have something to fool around on. It was listed as a 2013 and my first thought was the seller was just incorrect on the year. The more I research i think it actually is a 2013 (10th character of VIN is N). I think its some kind of economy version that used old left over frames and cheaper suspension and brakes. If that's true I don't know anything about this version. Can anyone fill me in on details? Specifically the suspension and brakes?
New boot day😁 forma boulder comp,size 45 first impressions are they are a lovely boot nice fit should break in nicely i bought these as I can’t feel a thing with my x-power mx boots,obviously not as protective but as far as trials boots go they seem really sturdy.
