- Today
Hi everyone, I just joined, and I really appreciate all the knowledge here, and I'm ready to share my own
Trying to replace the kickstarter spring, I can’t find one, I don’t have the original to compare to the many varieties available on eBay, does anyone have a diagram of this complete assembly/installation. ( 1966 Montesa scorpion 250)
Cosa intendi dire con "non riesci ad aprire il campanello"? Per favore, pubblica una fotografia del campanello.
@ FHG Sounds familiar , One listens to a machine pretending to be a person , you then take its advice , you believe what it tells you and then everything gets broken , affects you personally and costs you money.
The old Beta`s had to have a special float setting. https://www.trialsport.com.au/beta/Manuals/mikuni/
The lower fork legs wear oval in the bore after years of use depending on how often the oil was changed, measure the bore in the lower legs for true to round before investing in a weld repair. Very few will have the tech to weld that material efficiently.
It's always half way up the emulsion tube because that is the part most sensitive to the correct fuel level.
Thks , spent a few more hours knelt by the techno today , no difference! I took the header off and applied a lighter to it , it lit up well and burnt for about 30 seconds so yes there was fuel in there. I kicked the bike over without the header and it started briefly. I also did a compression test 150PSI . When the header was off I noticed a pin hole about a inch from where the flange is so I,m wondering if this is not helping things - not the fuel leak but basic running when I can get it running that is. I think I will get a new valve jet and seat as although it appears to seal when level maybe when its at a angle its binding on the side. I also noticed the tang plate float pin is really loose , maybe that is wriggling loose and binding on the carb. I think a new carb would be the best route if I cannot buy the valve jet/seat so will have to see which way it goes. One question I have is what does the manual suggest is the correct float height , 15mm from the carb casting or should I do the lining up method withthe pilot jet tower ?
FHG started following 1977 Montesa Front Fork Broken
I broke the bottom of the lower fork on my Montesa rebuild. ChatGPT told me to hammer down....the forks come up.... I should have realized but didn't. I heard about welding but I think here in Alberta, CA it would be very expensive and no warranty or guarantee. I see exact parts on ebay in the US that look almost new. They look too good to be true but I assume I could rebuild the forks with new seals... Or is it best to try to get an entire fork - upper and lower? The old shocks seemed to be functional 25 years later. Any recommendations would be great.
Hi Cello, I have 3 Techno's and all 98 black models. Carbs can be an issue especially when leaning the bike over at sections, unless you turn the petrol off. The Mikuni's Vm 26?? are hard to source spares for (I needed a carb top and looked for ages). I'd suggest buying an OKO copy carb off flea bay, (around £30) and try it. As for the float height, I set mine too the manual, floats around level with the carb body, also attach a pipe and with the bowel off simulate its correct position, and manually work the floats to ensure the needle valve stops the fule supply. Best of luck and keep at it, as the Techno's are a great bike and still competitive. Jim.
From what you are saying it seems that you have a problem with an incorrect float height or the float arm is sticking open for whatever reason when you tilt the bike. If it were me I would bend the float arm central tang (that touches the fuel inlet shut off valve) upward slightly so the fuel shuts off with less fuel in the bowl. The reason your bike will not start is that the crank case is flooded out. When this happens take the plug out and clean and dry it off put it back in then try holding the throttle wide open while kicking it over , if it is mildly flooded it will start but not if it is seriously flooded.
Checked the floats , they appear to be intact no cracks etc and float in petrol fine. I turned the fuel on with the carb off the bike no leaks but then fitted it to the bike and it *issed out on the stand, hold the bike vertical and it stopped but still wont start , not even a hint at catching. New plug on the way and will do a compression check while I wait, thks for your suggestions.
Have you pulled the header pipe off the bike. Sounds like it is full of fuel. The crank could be full as well.
I must be the only one in the world that checks a float needle and seat by removing the float bowl and lifting the float with my finger to see if it shuts off the fuel flow at the right height or not at all 🤔
https://www.trialsport.com.au/beta/Manuals/mikuni Forget the REV 3 bit a Techno and REV3 are virtually the same with a different Frame.
@cello have you checked that the floats actually float in a bowl of fuel , over a period of time they can become porous and fuel gets inside stopping them from being sufficiently bouyant.
I run 50% premium pump fuel mixed 50% with 100 octane race fuel, oil is 1% amsoil sabre. Makes the bikes run good and very little smoke or exhaust residue. Ideal float level is when the fuel level is half way up the emulsion tube, because that's when the emulsion tube can function best, if fuel pours out the float bowl vent the seal on the float needle and seat must be failing to regulate the fuel height. ... or a vent pipe is incorrectly routed, that could do it.
Thks Lemur, bike wont start atm so cant tell what effect the front wheel height has. Also the reeds are there to prevent back pressure from the cylinder side not the carb side tbmk so doubt they would have any effect on the problem, I did take a look tonight and they looked fine. I'm wondering if the fuel mixture I put in now is too oily and or if the spark plug has seen better days, replacing it anyway and will bung some neat fuel down the airbox to see if this works. I also cleaned the carb , set the float height to 15mm where the tangs are not level with the casting, slightly downhill looking at it from the side. I hooked the fuel line up switched it on and no leak fitted it to the bike and with the bike on its sidestand switched the fuel on and...........it *issed fuel out again LOL FFIN LOUD, FFIN THING
I've acquired an Aprilia Climber. It's a 280, a 1993 model. Tommy Ahvala won the world title in 1992. So this is the replica, celebrating the Italian manufacturer's world championship victory. I fitted a Paioli RSD fork while waiting for the original Foral to be restored. It looks really nice. I spent a lot of time on the Foral fork. Bertrand Quartier had warned me about the rather poor quality of this component. Indeed, it's not great. Furthermore, a previous disassembly by someone less experienced had damaged the hydraulic system. I repaired it to get it working again. The fork was binding badly. The friction bushings were completely worn out, and the oil... well, it was like crude oil. I found a complete new internal assembly for the hydraulic arm. If my repairs restored functionality, the whole assembly would have been deformed. The poor guidance would have quickly damaged the untreated shaft.
Alexgilardi4356 joined the community
Cota 242 clutch plates, something is odd here
Alexgilardi4356 replied to stefan_s's topic in Montesa
Ciao, ho appena comprato una Montesa Cota 242 e, dato che è rimasta inutilizzata per diversi anni, i dischi della frizione si sono bloccati tra loro. Tuttavia, non riesco ad aprire il campanello. Puoi dirmi come si fa? Grazie mille. -
An extra expensive 1.2 pound third party tube/rim lock designed for tubeless tires is randomly installed on a single TRS production bike tube type front wheel 🤔 no, TRS is not that tiny. Now if the rims were to be anodized Pink instead of Red because the manufacturer ran out of anodize materials, TRS is a small enough company to let that slide, but that process doesn't cost extra money and require extra holes drilled to stuff a second rubber inner tube into the front tire.
My '23 TRS has front rim lock 180° from valve. My Beta dirtbike has a Tublis on rear because I put it there. High pressure valve and rimlock incorporated about 4 spokes away from valve. Heck maybe they fitted them for a while. They are a tiny company.
Thank you both. I looked at the eBay item and it was in bad shape. There is substantial damage to the fiberglass and the actual seat is in very poor condition. I have seen the covers and I may have to go that route if I can’t find something better.
Thank you. You get it, don’t just settle for what the docs say. Never forget the power of exercise and fresh air in regard to health. Challenging ourselves with new activities is powerful medicine.
SlowDave, keep showing the doctors they’re wrong. I had an accident (electrocuted) when I was a kid that kept me hospitalized for an entire year. The doctors said I wouldn’t be able to run or ride my bike anymore and that I’d be in a wheelchair in my 50s. Well, I did run again and even skied competitively in college. I’m 65 now and still going strong. Doctors don’t know everything. Also, I had a 1974 TY250 myself that I rode in high school after I was released from the hospital. I’m looking for one now myself. I loved that bike.
