Michael272m started following 2000 TDN Videos
There is a new release to the TechnoVideoMoto-trials YouTube channel. https://www.youtube.com/channel/UCMeRIlapdX-84E-cOV0vPZg/ Since the USA Men were victorious for the first time in 20 years, I thought it would be fitting to show the very first time the guys were able to top the podium. Part 1 showcases the men's event. https://youtu.be/m5AgrnNc2fc Geoff Aaron, Jess Kempkes, Ray Peters and Cory Pincock from the USA. World riders including Doug Lampkin, Steve Colley, Takahisa Fujinami, Kenichi Kuroyama, Albert Cabestany, Marc Colomer, Marc Freixa, Tommi Ahvala, Diego Bosis and more. Part 2 features the women's event. https://youtu.be/V_fk1ijcLxs Pam Debruin and Debbie Evans-Leavitt for the USA plus Kerrie Brokaw and Laura Bussing. Laia Sanz, Maria Conway, Iris Kramer, Christy Williams and Kerry Williams and others also rode. Also included are tours of the Honda-Montesa factory, GasGas factories, Spanish trials motorcycle display, Montesa museum and R&D site.
Kezj joined the community
Hi, To anyone who is having trouble bleeding their trials rear brake. This just worked for me after spending a lot of time trying. Remove reservoir cap and empty fluid with a syringe. Then attach a pipe and syringe to the caliper bleed nipple and secure with a jubilee clip. Remove syringe plunger and fill with dot 4, allow air trapped in tube to rise then put plunger in syringe. Open bleed nipple and force fluid back to reservoir, emptying with a second syringe. Once done couple times, leave reservoir filled and put cap back on. Then open bleed nipple and pressurise caliper with the syringe and close nipple whilst keeping pressure on syringe. Keep syringe attached and with fluid in at all times, no air. worked for me after rebuilding master cylinder and buyer a new caliper aswell. Might be of help to someone.
I read that to test theamount of water in oil , heat some metal up and drop a drop of contaminated oil on it , if it fizzes lthen it needs changing , if it does not then it might only be the discolourisation you are noticing from the prevous seal failure. It should be ok on the 2,d or 3rd oil change, get the bike warm for a good 30 minutes to see if it evaporates and changes colour.
Yes I am sure it is , use whatever works to stop the loss of air.
It's a well tested and proven fact that cyanoacrylate adhesive is far superior to bung plugs when you want to field repair a slice or puncture in a trials tire, particularly if it is in the sidewall of a 2 ply trials tire, plugs will just make a mess of the damaged area when it's a sidewall split.
It is a lost in translation thing . https://www.trialsuk.co.uk/puncture-repair/Apico-puncture-Repair-Strips---Tubeless-Tyres---Pack-30
... no dude that's just plain stupid.
Yep, looks like an 11 racing to me
- 1 reply
- 1
Yes and a packet of dog turds.
For puncture resistance on rocks yes of course , as far as I am aware X light is for indoor trials. It would be odd if a major tyre manufacturer would spend an astronomical amount of money on tooling and R&D to produce a tyre that a few trials clubmen had suggested as a desired option while chatting in a bar. I am going to guess that its development was requested by the elite riders specifically for indoor events in the same way that Adam Raga requested that the older GASGAS would benefit from losing a lot of weight to help with hopping and skipping around which resulted in the pro version.
sherpa350 started following New to me. Gas gas txt300
Good evening. Thank you for accepting me. I've been practicing trials riding since I was 8 years old, always with Bultaco. My last bike was a Sherpa 350. Now, at 56 years old (oops!), I'm getting back in the saddle. I bought a Gas Gas TXT300R, disassembled. I found that the kickstart pinion is bad, as is the drive pinion. I've already ordered the replacement parts. I'll finish putting it together this week. Otherwise, it's pretty complete. I have a question about the VIN. According to the paperwork, it's a 2008 model, but it looks more like a 2011 to me. Could you help me? Thank you very much. I've attached a photo and the VIN. Thanks. VIN: VTRTG3003M0116194
You can fix most problems with crazy glue 👍
The top riders use x11's.
I dont know why so many people dislike X-lights I have used most brands and versions and the X -light seems good to me. The top riders use them and they do not seem to complain.
If its of any use to you ... in the UK for competition the Michelin X11 is considered to be the best tyre for grip in all conditions and lasts the longest , quite a lot of riders in the south of the UK where Trials are run in woodland with little rock/stone but plenty of mud swear that the IRC WINNER TR is the best rear tire to use , they usually use a Michelin on the front wheel.
If anybody wants to trash their expensive soft compound radial tubeless competition trials tires after one use, you can throw them my way. Even the worn out tires work good for winter riding after you pump about 600$ worth of carbide grip studs into them 😎
The michelin is the best, nothing wrong with the IRC. If you find an 803 buy all they have. the rest of us can`t find them. LOL The TL01 is crap I threw mine in the trash after one event. And Dunlop knows this!!!
I bought the Grib last year at a black friday offer. Chose Grib mostly because it was sent from a country inside EU. But it is a beauty! And my bike haven't run this good ever. I know some will say that you loose some power in the bottom end. I haven't felt this at all. But I'm probably not the best too say either. Looks da.. good and is probably 1/4 of the weight. Do it! As an early Christmas present
- 1 reply
- 1
So by chance I’ve been looking at trick exhausts 😔 I knew I’d start wanting one. The Grib and the JP. Yeah I know the 200 doesn’t really need one but there’s plenty of things in life we don’t need. They look bloody nice on the bike and theirs the weight saving to consider too Anyhow what’s your thoughts on these two or any other not mentioned Do they do what they say on the can or is it just bling and weight saving?
I'm a brand new trials rider, so I have no other feedback other than I bought the IRC TR-11 due to them being half the cost of the Dunlop TL01 or Michelin X-11. The TR-11s were about $250+tax for the pair. I needed to replace the original tires on my 04 TXTPro so honestly I'm sure anything is an improvement. TrialsSuperstore only sells the TL01 and X-11 if that tells you anything... I also looked at the Dunlop K950 but being DOT rated, it looked more like a dual sport tire pretending to be a trials tire. Reviews stated that the rubber compound is way harder than a true trials tire and therefore less traction.
X-lite is the worst buy IMO. Expensive, wears quick and ive found I have to run them at a higher pressure which negates most of its benefits. Anyone tried the new CST tyre? looks good, and £85 for a rear
Note that if there is no R in the tire size it's not a radial 🤓 Remember when the Michelin Light came out and they were less money then the X11 version, they are cheaper to produce and have now become the most expensive option available because of supply and demand. The X11 radial is still available and can be had for significantly less money 👍
I was just looking to buy some until I seen this..haha thanks great idea im going to do mine today.
