This stream auto-updates
  1. Past hour
  2. All information is needed , actual bike model etc what is it Ducati system or Motoplat ?.Where are you USA , UK etc ?
  3. Yesterday
  4. Hi Feetup, how did you modify the trees to get paralel offset ?
  5. Looking for a cdi module as I broke the pins off mine I try was motorplat the last numbers were 406 bike used to run but now it’s not running could do with some help
  6. I'm glad you mentioned using the KT triple clamps as well as the forks. Did you realise that KT triple clamps are a lot further apart than TY triple clamps, so there will probably be some work involved with fitting the KT triple clamps into a TY frame. I haven't tried this to know what's required but at least the angular offsets of the KT fork tube holes will be incorrect if the KT triple clamps are moved closer together. The other stumbling block there is that the TY steering stem may not fit the stem holes in the KT triple clamps. As for attaching the TY brake link, it would be pretty easy to make a clamp that fits around the left side KT fork bottom for the TY brake link to attach to. No idea what spacers might be needed for TY wheel in KT forks with KT triple clamps. If you have a TY wheel or TY forks in their triple clamps and some KT forks in their triple clamps, you can measure them up and compare. Also have a think about where the KT fork tubes will end up at full lock relative to the TY fuel tank. Unless you limit the steering angle, I suspect they might hit the TY tank. This is because the KT triple clamps are designed for leading axle forks which usually positions the fork tubes more rearwards when straight ahead and closer to the midline of the bike at full lock, compared with (in-line axle forks) TY triple clamps. For what it's worth, the standard angular offset for both sets of triple clamps is the same (1.5 degrees). I modified my KT triple clamps to reduce the angular offset to achieve the same trail dimension as a TY (to make my KT steer better). You could do something similar to a set of TY triple clamps to achieve the same trail as a KT250 with a lot less trouble than doing a front end swap. However, I'm only guessing that this is what you are trying to achieve. What are you trying to achieve?
  7. I am seeking a lighting and electrical wiring kit stripped from any of the ST250 through 300 series. Lights, taillights, horn, regulators wiring harness all welcome. I'll pay top dollar in the USA. Don't ask why....I just need it to get licensed...then off it comes again. Lemme know Phil
  8. FANTASTIC web site link on the OSSA. Simply FANTASTIC!
  9. Last week
  10. Not suggesting 2mm more base gasket. Recommending 2mm (or any other value your experiments show to be helpful) total squish clearance. The squish may already be on the order of 1.2mm. Yes, it will change the port timing, but I have not seen that small change cause negative side effects. If anything, it makes the bike slightly easier to kick. It's also easily reversible. The Sherco uses o-ring seals for the head/cylinder interface, which I would leave alone. Machining the head is another, less reversible, route. Increasing the combustion chamber's “blend radius” is another way to soften the hit. I touch on that here: https://www.ossa-efi.com/home/engine/heads Also, a bit on reeds here: https://www.ossa-efi.com/home/engine/reed-valves I'm going to retract my G2 idea based on RonH's experience. I now see it's intended to be a blend of the slow and fast rates. Whereas Ron's idea for a “slower than slow” tube is more what you need.
  11. I like your suggestion with the cam. Thank you for your help.
  12. Adding 2mm to base gaskets will also change the port timing slightly, whereas increasing the head gasket will not. Is it your recommendation to lower compression AND change port timing by using a base gasket, or just to lower compression by using a head gasket?
  13. Two cheap, easy, reversible changes: Retard ignition timing. Increase squish clearance to ~2mm via additional base gaskets. Additionally, if you are good with the clutch, a flywheel weigh can help slow things down. A company called G2 makes a cammed throttle tube called the Tamer: https://www.g2ergo.com/shop/g2-trials-throttle-tube-progressive-rate-sherco/
  14. Hey pmcand, I had the exact same problem with my bike. I did three things to help calm my 2023 Gasgas down. 1st - I installed a flywheel weight (it helped some) 2nd - I installed a 1mm head spacer to lower the compression. (It helped a little more, it’s much easier to start too) 3rd - I modified the throttle tube. (This helped a great deal) Regarding the throttle tube, there is a cam where the cable runs around the end of the tube. Both fast and slow throttles have them. I had tried a slow throttle but the change was very minimal so I bought an aluminum one (slow again) from G2 Ergonomics. It also produced no noticeable change that would work for me. I lived with it for two years until I had the idea of modifying the tube. I simply removed the throttle tube and used a Dremel to ease the cam to a more linear pull. It took me about five minutes to grind it down. I have a photo showing how I modified it in the link below. I put a dashed line in to show what material to remove with a before and after shot. The change from a “scary” throttle response was exactly what I needed. It costs nothing to modify it compared to the other mods I listed. I guarantee this, modifying the tube, will get you what you want. Feel free to ask questions. Good luck! https://flic.kr/p/2rPhx56 Oh, we happen to be the same age. When you and I were riding trials in the 70s the throttles were linear and smooth. The new age throttles have the cam we didn’t back then. That quick throttle caused me a serious crash with a punctured lung and six broken ribs. I know exactly what you’re going through. Let me know if the link doesn’t work.
  15. Sell it and buy a 250 is the least amount of messing about.
  16. The throttle on the 2012 is WAAAY too scary. Comes on way too hard with small throttle inputs. What methods are there to calm this beast down? 1) What alternatives are there to slow the throttle cable twist grip? I use the Domino side pull (slow) trials version now. 2) Changes to timing? Advance or retard? 3) Changes to cylinder compression or gasket thickness? 4) Changes to ignition mapping available? 5) Porting mods? 6) Reed mods? 7) Cylinder alternatives? Is there a 250 piston/barrel available that will fit on the 290 engine? I am 65 years old and a expert-level rider in my previous life, so don't give me this "You gotta train harder and get used to it" approach. I don't want to shoot up and over 15' vertical steps...I just want to slow things up a bit.
  17. It is impossible to bounce the rear on the 2012 . Can't even get it off the ground no matter what I do. Front brake is clean and acts like a trigger on a gun, but still won't lift the rear end. Damping is WAAAAAY too slow. Sag is about 10-15mm with no rider. Is there any damping adjustment on the stock 2012 rear shock and where is that bugger anyway?
  18. feetupfun, To be clear I would want to use the KT triples as well, so if using the 175 wheel a spacer would be needed? Still not sure how to anchor the TY brake arm. I think the KT uses a lug cast into the backing plate and lower.
  19. Yes 4 pot front brakes were a huge advance in brake control compared to 2 pot. The EVO also feels substantially lighter to ride than the Techno. I remember riding my first Rev 3 in about 2001 and being amazed at how light it felt to ride compared with a Techno.
  20. I've done it the other way around, fitting TY250 forks to a KT (wanting to increase the trail). I used a TY wheel. An axle spacer was needed for this. It was just an experiment and I went back to using KT forks on my KT. There were two problems with the TY forks on the KT. The amount of trail was too much which upset the steering and the front mudguard hit the exhaust header on full compression of the forks. I then modified some KT triple clamps to provide only about 5mm extra trail over standard and was very happy with the result. If you fit KT forks to a TY250, the KT wheel assembly will be a bit too wide because with KT triple clamps, the fork tubes are slightly (2-3mm) further apart than with TY250 triple clamps. I've not tried to fit a TY wheel to KT forks. KT forks are longer overall and have more travel than TY250 forks and would reduce the trail by about 20-25 mm due to the leading axle design. They are functionally very similar inside with the main difference being that the KT forks do not have anti-topping springs. They are so similar inside that you can use TY internals in KT fork tubes and vice versa. It sounds like a fun, interesting project.
  21. Beta or Vertigo 200 or would be my vote based on the size of the wife and easy of starting. I have known several people who have had smaller riders Daughter's and wife's that have done well on the 200's. If you can't find a 200 I would vote a 125 as my daughter did great on one for a number of years even riding at 3000-6000 ft. If she had stick with it a bit better I probably would have upgraded her to a 200 as that would have made the most sense. However based on the fact that by the time she turned 18 she was 5' 10" 130 lbs and even able to start my 07 4RT 250 (though not great at it) I probably could have gone with most 250's by then. Good luck.
  22. Tr1AL
    SINCRO
    https://www.instagram.com/reel/DSX5PKJDLJs/?utm_source=ig_embed
  23. Has anyone used KT250 forks on a TY? If so, pros and cons? Did you use a KT or TY wheel? If using a TY wheel, how did you mount the brake arm? Possible scenario is KT250 forks used on a TY175 to have larger/stiffer 34mm front end to get rid of the flex with the small 28mm(?) 175 fork. I haven't been able to source a TY250 set and came across a set from a KT. I was also wondering how the leading axle from the KT would work. Hoping someone has tried this over the last 50 years.
  24. Thats worth knowing. thanks Feetup! I must say the ancillaries especially the brakes are much better then the Techno's and they are vitally important much more then the power delivery , I found that out the hard way! I think its a 250 but have not had the head off to confirm, compression is way higher the the evo and you can feel it on the kick starter, she does start normally on the 2nd or 3rd kick after being left for a few weeks. I did measure the bore through the exhaust port when I got her and althouh a rough measurement think it came out at nearer a 250 then a 270 bore. Parts being hard to get now with the tail piece in particular looks almost brand new so not sure I will take her out much unless I can find another tail piece/rear mudguard at a resonable price such is my looping tendancy atm
  25. The only way to find it out is to compare. I have no data about it. The bike feels super light and well balanced. I already assembled the engine back, currently I need to adjust a squish clearance for 1.2 mm. It was 0.9. I ordered 2X0.4 gaskets on top of 0.5 base gasket. Also, the piston feels a bit lightweight and I'm wondering about engine balance.
  26. Does it have the same transmission ratios as the trials engine?
  27. A standard 250 1997 Techno has a lovely soft motor. Technos came out in 1994 and were highly responsive - probably too responsive for the average rider. The 1996 model was made much easier to ride for the average rider and it stayed like this for the rest of the years of the Techno (96, 97, 98, 99). By the way, is your Techno a 250 or a 270?
  1. Load more activity
