- Past hour
Swainy joined the community
Hi I’ve just bought a 2001 315 it looks like it has had very little use ,I was going over it and on removing the carb there is what looks like a restrictor plate in the manifold with what looks like a 20mm hole in it ,is this standard? As It is not shown in the parts catalogue, thanks for your help.
- Today
Sorry for the lack of updates... got a bad flu that kept me inside for the whole week. Received the spark plug. Tried to buy an used Polini PWK carb but most sellers are asking €80 when they cost €100 brand new. I was a bit in hurry as I wanted to diagnose this issue (still pretty sure it's due to the stator or the coil, though!) so in the meantime I ordered another PWK (Koso clone), this time it's a 30 (the other one was a 28mm). I'm pretty sure the bike will still have the same issue as it's not carb-related. I was considering the idea of removing the flywheel to replace the crankseal on that side too, and while it's out, to put the other engine's stator/flywheel and see if the bike behaves differently. Not sure they have the same flywheel as one is an Explorer engine and the other is from a Pioneer... in pure theory I'd expect a lighter flywheel on the enduro, but I guess the stator itself will be exactly the same.
Billydave joined the community
Off-road TTR motor is the best option, but will be hard to find cheap . Street bike YBR motor swill be the same fit as the TY but easier to find second hand /used and cheaper.
I ready only now your very good and detailed analysis, I like a lot the Yamaha engine installed on my scorpa ty125 2004, now I wont upgrade the engine with big bore cylinder 62mm but I don't want modify the engine installed because I don't know how long time the upgrading need, therefore I'm searching a spare engine, do you know if the xt125 or ybr125 are the same of ty125?....if not do you know the main differences? Thank you in Advance.
Struggle with Technical Data for Sherco X Ride 290 2017-2018
Cherokaa87 replied to Cherokaa87's topic in Sherco
To be honest I didn't tried it yet. I thought there was no point to get a respond before. Ill go for it even for a little chance. -
mcman56 replied to Cherokaa87's topic in Sherco
Have you tried contacting the Sherco factory direct? A few years ago, I purchsed a 2001 Beta Rev3 and could not find documetation. I emailed the factory. They sent me photocoppies of the owners manual and parts list. -
The world doesn't hate Americans like you konrad.
Recently had a conversation with a gentleman who is importing motorcycle parts from the EU. It seems everything is getting hit with a 50% steel/aluminum tariff because no one really understands exactly how to apply the tariffs. And if you think your goods were misclassified, the appeals process presently has a 9-month backlog. I have never felt more ashamed about being an American. Frankly, I can understand why the world hates us.
Your TrumpTax just did impact you, before this era I would have just mailed you the spare parts for free and ate the postage, now I don't want to.
Thank you so much for link, I get the manual, close one just with the delorto carb, I have the keihin and r16v shocks, other looks exactly the same. It's a X Ride 290 2017-2018 VIN: VNBXR29TRGA03236 So, it starts : (1-3 digits) - "VNB" indicates the vehicle was made in Spain; (4-9) - VDS follows "XR29TR", where XR could be a model, 29 engine and TR stands for category (as I assume); The 10th digit - "G" shows the model year 2016; The 11th digit - "A" indicates the specific manufacturing plant. I found a parts diagram for x-ride, Googled, put the effort, had a hard time and now I got a PDF, able to find the parts, but still don't have a manual. I'm just upset that it has not been provided on the official web site. Simple, that's a data just missing. Also, I'm using settings from a 2014 trail bike with 2.9 engine, for jetting the keihin carb. The pilot was 42 instead of 48 and I think it caused a cold seizure. Main Jet was in spec (125) and a needle was on 3rd instead of 5th position. So, I ordered the jet pack and I will provide the results once I'll get it right. -
Perhaps because you had something repaired outside of your country , your customs are the ones that charged you , if you had them repaired under guarantee you may not have to pay . it would have got stuck in UK Customs because there is only one person who works there . If tariffs haven't affected you personally its probably because you are wealthy enough to not care about increasing prices . As far as I am aware tariffs have impacted the World economy but I am not an Economist so it could just be propaganda . In a world full of liars who knows.
Hello . Modern genuine manufacturer spark plugs work very well, if you go to BETA UK website and search parts for your bike the plug that is listed as part # 2 is a BR7 ES that is it ,the end of your search . No other plug is going to be significantly better than an NGK plug and a BR7 ES is the plug for your bike . 3 different sources state that it is. So you have a choice with NGK of a standard BR7 ES or the same sized plug but with an iridium tip known as a BR7 EIX which is the anti fouling version of the plug but costs around £15 compared to approx £5 for the standard version .The EIX version will not increase horse power just supposedly it will give a brighter spark helping the motor to run better. Enjoy your bike. Regards Alan.
fanticisti replied to Cherokaa87's topic in Sherco
Is your bike a 2t-290, or the 4t-125 as 2t was 2013 & 2014, and 4t from 2016 and called TY125, but you mentioned 2017. Sherco website has broken link for X-Ride 2t-290 manual but try manualslib .com. MIght have another link on file if that doesn’t work. -
Flywheel weight comes in a kit with spacer ring and longer ign cover screws, but flywheel puller needed to insert the captive nuts to attach the weight.
I keep hearing about tarrifs but have yet to see any personal impact. What do people in other countries see? When ordering from the UK, prices are less VAT with no import duties. The last time I ordered something was about a month ago. However, last year I sent a swingarm to the UK for repair. It got stuck in UK customs for several weeks. It ended up costing a total of $100 with import duties and fees to get in the country. This really surprised me. Is that normal? There were no US customs cost when it came back.
Good points. I'll give eBay a go. Can't imagine I would find anything like that there, given the scarcity of the bike.
Im not saying they dont know, but the confusion is what the manufacturer is saying to use. I was asking if its update to use the BP plug as there may have been an issue when using the BR plug.
Shouldn't be too hard to find the same 250 top end on eBay, literally only difference between the 250 & 290 is piston, cylinder & head. No head gaskets on Shercos, there are o-rings around the studs on top of the cylinder & a inner & outer o-ring in the head Not sure how easy it is to fit a flywheel weight as the ignition cover is really close to the flywheel
Had the big end in my Jarvis replica fail yesterday, have already sorted the parts including doing the main bearings & seals Does anyone know where I can find the specs for the rebuilt crank - clearances for the big end shims or will the guy doing it for me be safe to just measure overall width of the crank before splitting & use that as finished size
Give him 10,000% anything is possible. 🤑
What if I give him a 4000% discount 🤔
Would not touch his pocket though .Tariffs are never passed onto the buyer, importers and exporters just suck it up. it works just like minimum wage increases so nothing to worry about.
Luker636 joined the community
Poor fella lives in the USA the tariffs he would need to pay would be astronomical and impossible to calculate.
You are just one of those types who makes everything straight forward and easy , why would any one want to do that when he can search for and then fit the full Scavini system at a cost of $550.00 , buy the HRC programmable ECU for $2000.00 buy the cables and software for $1000.00 after searching for it for a year and then get Rick Wakeman to play it all until it sounds right . I just don't get it.
The sellers on ebay say your bike uses a BR7 ES I would go with what ebay says. Forget what Lampkin BETA UK says what would they know.
