This stream auto-updates
  1. Today
  2. I hear you. It's very much not important, so if the risk is high, it's off my list of stuff to do. The design came from my son... he claimed to have designed it, but I'll ask. Looking at it now with a more critical eye, I see several errors and issues, so probably best to junk it and start over. Cheers... Paul
  3. Yesterday
  4. konrad
    Explorer wiring...
    May I ask where you got that design? Was it done by an A.I. chatbot?
  5. Sherco clutch holding tool https://www.thingiverse.com/thing:7079191
  6. Make sure your clutch lever is as far away from your fingers when you are holding the bar grip as it can be by turning the perch adjuster anti clockwise then adjust the small allen head adjuster screw that has a 10mm lock nut on the clutch lever so that there is approx 1mm of free play before it makes contact with the mastercylinder piston. this will seperate the clutch plates as much as possible when you pull the clutch lever in to give the least amount of drag at the clutch plates which will help to engage neutral. NB If when you make that adjustment your clutch lever does not touch against the bar grip then adjust the lever until it just touches the grip or when you crash the piston in the clutch master cylinder may become damaged. With this adjustment the clutch will be at its hardest pressure to pull with one finger.
  7. Even new bikes have problems sometimes , its all good because as you work through it you learn a load of things that will help you in many future problems. Have a good evening . Best wishes Alan.
  8. You could try removing what gas you can from the tank then elevate the rear of the bike so any remaining fuel moves away from the tap outlet. Did you try to drain fuel with the tank cap removed?
  9. konrad
    Explorer wiring...
    Yes, but I would advise caution. Pin 22 is driven by a component (Rohm SP8K22 dual N-channel MOSFET) known to have failed on at least 3 Explorers. This renders the ECU useless. I don't know of any trials model to which this has happened. I assume there is something about the Explorer wiring harness/easy start that's causing the failure, but I don't have one to investigate.
  10. A lot of those Gasgas 300s have been returned because there’s too much power the rider can’t control. That’s why you’ll find them for such a great deal. Totty79 gave you some valuable advice. I have a 2023 Gasgas and had to lower the compression and put a flywheel, slow throttle and taller (11 tooth) front sprocket on it before I was comfortable on it. It’s now an clubman bike. Also, I got my 250, brand new, on sale for $4,999. If you look you’ll find a good deal too. Try Motohunt: https://motohunt.com/motorcycles-for-sale?q=Gasgas+250+txt&sort=a and search for least expensive. I just saw this on https://motohunt.com/l/7046299/2024-GASGAS-TXT-Racing-250 for $4,999. I don’t know where you are but if you’re in the states you can have it shipped for a reasonable cost. I had mine shipped from Georgia to Oregon for $300 through Uship. Good luck!
  11. Thank you, that’s great advice. It’s a GasGas I am looking at so might think carefully!
  12. Depends on the bike, 300 SS Beta is probably ok, 300 Gas Gas probably not unless detuned.
  13. I have a 2016 Evo with the electronic petcock. I am getting no flow when turning the manual override lever. When I try kicking nothing dribbles out either. I need to pull the petcock to investigate. Is there another way to get the petcock open so I can drain the tank? I could try a hand pump to siphon out the gas but suspect there will still be a lot of gas flowing out when I remove the mounting bolt. Is there a cleanish way to do this? The odd thing is that the initial symptom was hard starting when cold or hot. The bike ran fine once started but I did start to get occasional odd noises in the exhaust. I adjusted the valves and cleaned the carb but when trying to start discovered this no flow issue.
  14. Hi, so I am an absolute beginner but I don’t think it’s me, I struggle to find Neutral to the point that I sometimes use my hand I also feel like I have clutch drag and wonder if I should replace the clutch with a Mitani ? I have changed the gearbox oil with the correct Elf oil and silkoline for engine both were Dark
  15. This should work with a high impedance input from PIN22. I'll build it in the coming days and see if it is a viable solution. Cheers... Paul
  16. Excellent! Thank you konrad. OK, I can drive a suitable transistor with that to turn on the "spare" warning light on the OE dashboard. Am I correct to assume the 5V is relative to the ECU ground on PIN10? It seems almost as if the ECU manufacturer didn't finish the job, or tried to save a bit of cost by removing the internal MIL lamp driver. Thanks again. Cheers... Paul
  17. konrad
    Explorer wiring...
    From my notes... There is a symbol on the initial 2011 wiring diagram called "Testigo Averia". That translates as “Fault Witness”. I called it the CEL (Check Engine Light) in my notebook. Another name is the MIL (Malfunction Indicator Lamp). Looks like OSSA made it part of an instrument panel in the 2014 wiring diagram. Reverse engineered it a bit. It sources 5 volts at only 5 mA, so not too useful to drive a lamp. Even an LED is pretty dim. But, you could easily read it with a voltmeter. If your bike does not start, see if ECU pin 22 is at 5 volts (with the bike powered by a battery). This would indicate the ECU thinks there is a problem, versus the bike just being recalcitrant. Wiring diagrams are here: https://www.ossa-efi.com/home/electrics/wiring-diagrams
  18. Cheers, typical of me to buy problems! 🙄
  19. Thanks Alan. Really appreciate it
  20. Hi all, I’m asking for some advice please. I had a go at trials yesterday having been off bikes for nearly 20 years. I had a go on a 250 and did well on a yellow flag course. The guys said I would be good to have a go at a club trial. I enjoyed the 250 and found it very manageable. Looking for a bike now and can see a good deal on a 300. is there much difference between a 250 and 300? I worry if I buy a 250, I’ll want to upgrade to a 300 but at the same time, while I got on well, o don’t want to be cocky and buy a bike that might be too much for a beginner. any advice would be welcome. Thank you
  21. Hello people, I'm tidying up a few wiring issues inherited from previous owners and I've hit an issue without an obvious solution. Can anyone tell me what the MIL wire from PIN22 on the ECU is supposed to do? It's currently connected in a very nonsensical way and I'd like to understand how it should be connected. Does anyone have specific knowledge? I've a loom with the six pin diagnostics connector and the easystart system if it helps. Failing that, does anyone know what happens to pin 22 in the cases of a fault and no fault? Thanks in advance. Cheers... Paul
  22. Thanks seal in and looking good so far , I wonder if the seal is this way round because the garter spring in the seal is not made of stainless-steel and hence would suffer from corrosion and ultimately fail.
  23. Yep, you have the most complicated and problematic carburetor design that was ever installed on a motorcycle so that they did not have to buy a fuel injection system from Honda. Most of the problems will be in the bottom half of the carburetor where the ethanol fuel evaporates out of the float bowl and leaves solids and corrodes parts, the top half won't be a problem until the rubber bits start to degrade and lose critical engine vacuum pressure. Avoid ethanol fuels if at all possible.
  24. Just bought the bike a couple days ago and need direction and guidance for repairs. No luck searching Google. Happy to have found this Awesomely informative site! Thank you all in advance.
  25. @Noel09 https://www.trialscentral.com/forums/topic/80228-fuel-tap-solenoide https://www.trialscentral.com/forums/topic/64519-beta-4t-fuel-tap-solenoid/
  26. @Noel09 www.betausa.com -support - trials - owners manuals = MIKUNI SE BSR 33-79 The information is all there. Regards Alan
  27. Hi, sorry more questions. I'm trying to figure out my fuel system on the 2007 rev 4T 250 4-stroke. Mostly out of curiosity so if anyone knows them and could fill me in I'd be very thankful. OK in the manual the fuel tap has a weird looking fuel tap? My doesn't have the same. I'll add some photos. Mine also has a fuel outlet at the back of the tank with a weird nob on it? The fuel outlet on the side of the tank doesn't seem to have an on/off? The fuel lines go into a little chrome cylinder which I'm guessing is a pump? It plugs into the wiring loom. The block connector the feeds it has 2 extra wires that have been cut? It also has a hot start cable that runs into the bottom of the intake manifold but some cut the cable at the headstock? Do I need this? Thanks again everyone for help and advice. Noel
  1. Load more activity
