cleanorbust
    1,116
Posts posted by cleanorbust
  1. 1 hour ago, smokey125 said:
    I agree would be more than happy with either of them. I’ve always like things that are a bit different and a Ducati for pre-65 certainly fits different!
    For reference the Peter Gaunt one is probably a 350 Sebring. Same as the pictures!
    Agree about a Ducati being a different option from the norm in pre 65 these days, but of course the Gaunt Ducati wouldn't qualify for that. Worth remembering that when it was built, it had to go up against the best Spanish bikes of the day in trials up to national level, which PG would routinely be riding, where everyone rode the same sections - no yellow routes, white routes or whatever!
  2. On 11/08/2018 at 1:26 PM, b40rt said:
    @pschrauber tell you tomorrow Patrik, long single lap trial with refuelling out on the moors. Typically the ignition would overheat and feel like it was running weak.
    It's on the TX300.
    Any update Ross? Did you go for the Pro or standard version?
  3.  Not sure if you're thinking of using this on a bike of yours or just moving it on.
    Does it leak? If not, should be worth sealing internally, giving it a cosmetic makeover on the outside and putting it into use.
    If it does leak, try a repair and if successful do as above.
    If for your own bike, replacing it with anything else would cost plenty and at the cost of losing the original Bultaco look.
    if it's just something you want to clear out, it's got to be worth something to a Bulto enthusiast
  4. 2 hours ago, T Gallagher said:
    I own a 2017 beta evo 125 2 t and now feel it needs more power I would like to know if it’s possible to buy a cylinder and piston from a 250cc or 300cc and put that on the engine or get it bored out and where I can get it bored thank you ...p.s. I live in bury manchester
    I'm afraid not. The 125 has a shorter stroke so even if the bigger barrel fitted you'd be looking at a new crankshaft, plus carb and CDI unit, possibly flywheel  and exhaust header too.
    The message is, if you want a 250 or 300, buy one.
  5. Yes, the Sherco has electronic ignition but since owning that I moved on to a 280 Scorpa, where it's possible to tweak the timing by moving the backplate. I run it a bit retarded for that soft, sloggy feel to suit old fashioned riding style.
    I also ride a 247 Cota, the very one I bought new in the 70s. Interestingly the recommended timing figure for that model changed from 4.0 to 2.5 mm btdc at some point in the 1970s, though there were no apparent changes to the bike/motor itself.
    I've always liked the adjustability and cheap repair options of points systems.
    • Thanks 1
  6. 7 hours ago, section swept said:
    Advance means the spark occurs earlier, retard means it happens closer to tdc. So advancing the spark in terms of crank rotation means it happens at for example 10 degrees btdc, advancing further the spark could occur at 20 degrees btdc....retard the spark and you move back closer to tbc.
    Yes, I know. 3.25 is advanced relative to 2.8. We covered that. My question was how advancing the timing would reduce running backwards, when it's over advance that causes it.
    Advance timing for more pep, retard it for softer response, as copemech says.
  7. 5 hours ago, section swept said:
    I’ll mention a famous name... Miller, he told me that setting the timing at 3.25mm btdc would soften the engine performance and reduce any tendency to start up and run backwards...very embarrassing! Having spent a very long time on ‘t’ shop floor on the tools and then ended up teaching others about the suck,squeeze, bang, blow process et al. I have to say that with a two stroke that has no advance or retard map, mechanism, or vacuum device to alter timing as stated should produce a slightly softer engine as opposed to one set at 2.8 mm btdc. I used this setting on my 325 Sherpa and it was indeed softer or docile if you will, compared with another 325 that was very peppy and much easier to loft the front wheel....and it would start and run backwards...usually into a tree, with rider cursing vociferously! Timing on that beast was 2.8mm and I use these examples to help our man with his 250 Ossa Gripper. That timing was easy to remember ‘325’. I dare say our man with the Gripper will go with 2.7mm or there about. This concludes today’s sermon, ?‍??
    ...but it's over-advance which induces a motor to run backwards, n'est-ce pas? So how come advancing it reduced such occurrences?
    Fantics were the most common in catching out their unwary riders in my personal experience. You'd reach the head of a queue, release the clutch and cause mayhem behind.
  8. 1 hour ago, section swept said:
    The underside of the piston on any downward stroke will create a pressure in the crankcase. If this pressure cannot vent or escape it will find or make its own way out, such as blowing oil out of the main bearing seals, forcing oil seals out of their housings etc. So your breather pipe looks as though it was the issue here. Make sure all breathers are correctly routed and fitted to the correct inlet or outlet, check to make sure no breather pipes or connection points are blocked. Excess crankcase pressure can severely restrict engine performance.??
    An article by one of my favourite authors on a topic related to your last sentence:
    www.cycleworld.com/its-obvious-once-you-understand-it
    • Thanks 1
  9. 4 hours ago, section swept said:
    Fraid not, advance means to spark earlier ie 3.00mm btdc as opposed to 2mm btdc and retard spark later...closer to tdc?
    I know. Your earlier message suggested the advanced setting (3.25mm. btdc) would give a softer response. It's the retarded setting which would do that. Hence, t'other way round.
  10. 6 hours ago, section swept said:
    Setting at 3mm btdc would not do any harm as a starting point, but the manufacturers specs must be around some where! Not too sure if your Gripper may have electronic ign. Fairly convinced it’ll be on contacts breakers so go with 2.8mm btdc for zappy pick up or 3.25mm btdc for a bit less go and a softer engine??‍??
    T'other way round. Advance the timing for more pep.
  11. Cloburn 180 trials are running a Vertigo open day this Saturday. I had assumed this would be one the test days Vertigo set up from time to time but a phone enquiry revealed it's actually to try to move on their second-hand Vertigo stock, which seems to tie in with other comments in this thread.
  12. Good for you. I was reunited with a 247 Cota which I bought new in the 70s after a gap in ownership of 34 years. Makes me feel as if I'm in my twenties again when I ride it.
    The strange thing is that of 15 trials bikes I've owned, that is the only one I've ever seen again. Where do these bikes go? I guess by now almost all of the pre 65 stuff has been pulled out of barns to be sold at huge prices, but there must be hundreds of Bultos, Montesas and Ossas lying around somewhere. There aren't many in twinshock trials.
    • Like 1
  13. You could try contacting the Yorksbire Classic club, www.yorkshireclassictrials.co.uk, look through their classifieds, post an ad yourself asking for help or ask around at one of the many trials they run. They'll have loads of members with first hand experience of Greeves and other Villiers engines bikes.
    • Like 1
  14. As another option, it shouldn't be too difficult to source a suitable flat sprocket for a different bike, even if you have to re-drill it to match your bolt spacings, or have one made, and use a spacer between that and the hub. This was standard practice with the Ossa MAR which also used a dished sprocket.
