Being fortunate enough to have a CNC mill I made my own ... (it's only a couple of bits of decent ally profiled)..good mod gets bike standing straight and rear end working better.
Ive just seen your 200 in TC Garage, looks too good to use, I am restoring one at the moment! I see yours has a different carb, Mikuni? if so what jets are in it? and what colour did you use for the frame?
NB...the new OKOs come with an angled throttle cable tube (the tube/cap on the Keihin on this photo). Which is great but this does not unscrew like the previous carbs and the Dellorto. This may lead to cable/wire length and cable adjustment issues. I'd guess you could partly correct this by using one of those universal replace throttle wire kits. But I'm not sure how you could introduce an inline cable adjuster.
If your converting from a Keihin or an older OKO just use the cap off of there.
Get one of the Amal alloy twist grips they used in the 80's they have a cable adjuster built in and look more durable than the Dominos we all use. I have one on an old Motesa Ive just bought and it looks fine. they are available from most Twinshock specialists
Sorted Drilled & tapped on the join between the steel middle and ally outer and scewed in grubscrews with a bit of locktite seems ok now, had to do it in a miller so the drill didint run off into the ally.
The Cota from hell has unleashed a new fault, the Flywheel boss is ever so slightly loose! I can feel a bit of rotational play only between the steel boss and the outer.
Will it sort of rivet tight again using a punch and hammer???
Does anyone know the method of contruction of these??
Will a Motoplat flywheel of another bike fit? perhaps a 248 349 of similar age or even Bultaco or Ossa and would balancing be an issue?
Found the spark and had it started...lots of top end rattle though!!!!!
I have checked the gaps between the rings and piston and its more than 0.15mm which seems a bit much, are pistons still available? I ve rung Sandifords and they dont have any?
Hi Just bought a Cota 200, because I had two in the 80's
And a few questions..
How can I tell if its a Montesa Honda? The Frame number starts MH and the front brake hub looks different to what I remember.
It's got no spark at the moment, I think its because the wrong coil is fitted, a Fesma coil is fitted and all I get when holding the HT lead is a tickle of a shock.
And to refresh my memory of points and things, the only wire used is the black from the coil on the stator which goes to the points, condenser and then to the HT coil, all other wires are just taped up behind the stator.
The resistance of the coil on the stator is about 1.6 ohms, is this about right?
And finally the kickstart problem that these bikes have, mine seems fine but i have felt it slip a couple of times! So is the fault a total breakage or do they just fail to engage???
08 Rev 4 Handlebars
in Beta
I got some of these Risers I think he could make any size you need.
