October 9, 200620 yr very nice surprising what visual effect those red and black tank decals have on the appearance of frame size Frame is smaller, about 20mm-25mm thinner around tank area
October 9, 200620 yr If they have changed it, it does not look that different i'm supprised beta have not made more of an issue about it ! I suspect it's more of a case of minor mods to the older frame rather than a major re design. if the tank has been squeezed in by 25mm i wonder if it still has the same tank capacity!
October 9, 200620 yr this was my thoughts they said lower back end nothing about front of frame but just going on whats been said
October 9, 200620 yr JUST CHECKED TO SEE IF PLASTICS WOULD FIT FROM 07 ONTO 06,ETC .NO THEY ARE DIFFERENT, THE O7 HAS A RECESS ON TOP OF THE TANK/FRAME AREA TO ACCOMMODATE THE NEW TANK PLASTICS AND THE O6 HAS A CURVED TANK/FRAME TOP. THE BIGGEST DIFFERANCE APART FROM THE FRAME WE HAVE NOTICED IS THE TRIPLE FRONT CLAMPS,AND THE FAT BARS,THEY GIVE THE FEEL AND THE LOOK THAT THE FRONT END IS MUCH LIGHTER THAN PREVIOUS MODELS AND THE CLAMPS ALLOW MUCH MORE STEERING LOCK THAN PREVIOUS MODELS,AS THE OLDER MODEL STEERING STOPS NOW DONT TOUCH THE STEERING TRIPLE CLAMPS ON FULL LOCK ALLOWING A TREMENDOUS AMMOUNT OF STEERING LOCK. THE 07 HAS TO BE SEEN IN THE FLESH AS IT LOOK VERY SIMILAR IN THE PICS THAT HAD BEEN PUBLISHED PROIR TO ARRIVING IN THE UK,BUT WHEN YOU LOOK AT THE BIKE IN THE FLESH IT LOOKS A TOTALLY DIFFERENT BIKE,FRAME HEADSTOCK LOOKS THE SAME BUT TANK AREA COMPLETLY DIFFERENT TOP AREA AND HEIGHT OF FRAME,ALONG WITH LOWER REAR END.BUT THE MAIN DIFFERANCE IS WHEN YOU STAND ON THE BIKE TO RIDE IT,ITS STILL GOT THAT DEFINITE BETA RIDING POSITION BUT MUCH IMPROVED ,FOOTPEG POSITION MUCH BETTER,AND WITH THE NEW BARS AND CLAMPS THE FRONT END IS CONFIDENCE INSPIRING. Edited October 9, 200620 yr by highlandtrials
October 9, 200620 yr MAD...N... RICK Any other manufacturer would call these mods a totally new model .......The Frame IS VERY MUCH DIFFERENT..The 07 plastics will not fit any others.. Niether will many of the gearbox parts as there are a page of Lighter changed Pieces... The Fork clamps are completely different !!!! Both of them ... The Frame has also changed by the footpeg mounts to be thicker and stronger.. yes the capacity of fuel has changed about 1.5 tenths less.. If And WHEN you actually look at one next to a 06 or older you will see an incredible difference in Size ... The weight reduction is very signifigant as well ... 3.6 lbs or 1.5 kg approximately.. LOOK BEFORE Sounding OFF The new shock length and settings are PRIMO !!!! ALL AROUND NEW FEEL AND POWER.. Edited October 10, 200620 yr by Ron
October 9, 200620 yr You lot are gits, I know, just bloody know I,m going to be begging at lloydsTsb in the week, now stop it
October 10, 200620 yr Now then anyone have the date for the BVM test day? bloody hope I can get this finger fixed in time can`t wait too have a go on one of these and will be my first oppertunity of riding the other offerings too!
October 10, 200620 yr Heath, bike looking good mate, nice repsol sticker on the rad cover, must have taken ages to do that, work time or home?
