doogle Posted April 24, 2007 Author Report Share Posted April 24, 2007 I will have a pink carnation in my button hole and a copy of the Daily Sport. Link to comment Share on other sites More sharing options...
atomant Posted April 24, 2007 Report Share Posted April 24, 2007 I'm easy to spot, fat git with big camera Bit like Andy then Good luck with the Weather all you nutters... errr I mean fine men (and women) taking 6 days of that on + 5 days of recuperation Link to comment Share on other sites More sharing options...
slapshot 3 Posted April 24, 2007 Report Share Posted April 24, 2007 Bit like Andy then nooooo, I'm nothing like Andy, I don't smoke..... Good luck with the Weather all you nutters... errr I mean fine men (and women) taking 6 days of that on + 5 days of recuperation Get your butt up here Beardsall, you know you want to Link to comment Share on other sites More sharing options...
atomant Posted April 24, 2007 Report Share Posted April 24, 2007 Good luck with the Weather all you nutters... errr I mean fine men (and women) taking 6 days of that on + 5 days of recuperation Get your butt up here Beardsall, you know you want to Yeah, I would like to go - Will decide at the last minute.. Basically after I have checked the Weather ( The southern woos that I am ) even though Beardsall is a solid Yorkshire name Link to comment Share on other sites More sharing options...
slapshot 3 Posted April 24, 2007 Report Share Posted April 24, 2007 Forecast info will commence probably Friday, unless the webmaster wants to use some amateur mob..... Link to comment Share on other sites More sharing options...
Andy Posted April 24, 2007 Report Share Posted April 24, 2007 Forecast info will commence probably Friday, unless the webmaster wants to use some amateur mob..... Now let's see... You told me it was going to snow so us Scooby boys could have some carpark fun - you got that wrong You told me it was going to rain at Kinloch for the Brit round - you got that wrong Who exactly are the amateurs? Link to comment Share on other sites More sharing options...
slapshot 3 Posted April 24, 2007 Report Share Posted April 24, 2007 (edited) Forecast info will commence probably Friday, unless the webmaster wants to use some amateur mob..... Now let's see... You told me it was going to snow so us Scooby boys could have some carpark fun - you got that wrong You told me it was going to rain at Kinloch for the Brit round - you got that wrong Who exactly are the amateurs? It was raining...if you been three thousand feet up was going to add a pic but it won't let me...sorted 1200UTC (1 pm) 03/05/07 Orange bits are warm air, surface temps about 22-24 degrees, dry patchy cloud light easterly winds (best kind for Fort William Green and Blue colder and suggest wind and rain. What we want is the high pressure warm air over the atlantic in the Pic to drift north and east towards the UK, that would be nice. Edited April 24, 2007 by Slapshot 3 Link to comment Share on other sites More sharing options...
bigfoot Posted April 25, 2007 Report Share Posted April 25, 2007 (edited) It was raining...if you been three thousand feet up Donald Wouldn't rain at 3000ft still arrive at ground level as some point soon afterwards? Edited April 25, 2007 by Slapshot 3 sorted quotes Link to comment Share on other sites More sharing options...
slapshot 3 Posted April 25, 2007 Report Share Posted April 25, 2007 (edited) It was raining...if you been three thousand feet up Donald Wouldn't rain at 3000ft still arrive at ground level as some point soon afterwards? Not always, on that afternoon it was evaporating before it got any where near the ground, one of our higher gauges above Blackwater was registering rain, on our radar we had a band of rain right across the north west but nothing hit the ground till much later in the day. The phenomenon is called Virga Virga Edited April 25, 2007 by Slapshot 3 Link to comment Share on other sites More sharing options...
bigfoot Posted April 25, 2007 Report Share Posted April 25, 2007 In meteorology, virga is precipitation that falls from a cloud but evaporates before reaching the ground. At high altitudes the precipitation falls mainly as ice crystals before melting and finally evaporating; this is usually due to compressional heating because the air pressure increases closer to the ground. It is very common in the desert. Now I understand. Kinloch is indeed a well known desert area. Link to comment Share on other sites More sharing options...
slapshot 3 Posted April 25, 2007 Report Share Posted April 25, 2007 (edited) In meteorology, virga is precipitation that falls from a cloud but evaporates before reaching the ground. At high altitudes the precipitation falls mainly as ice crystals before melting and finally evaporating; this is usually due to compressional heating because the air pressure increases closer to the ground. It is very common in the desert.Now I understand. Kinloch is indeed a well known desert area. I could have written anything, none of you would believe me but after 22 years of this job, it's nothing new. It is common in desert areas, but it does happen everywhere. Try this, maybe a better definition for all you doubting bigfoots..... "Virga is any form or precipitation that doesn't reach the ground. There could be rain virga or snow virga. But in either case, the precipitation evaporates somewhere on the journey from clouds toward earth. Virga, which is spelled v-i-r-g-a, is pretty common and you've probably seen it but didn't know it had a special name. It looks like a torn curtain hanging from the cloud, but only down about halfway to the ground below. Sometimes the air thousands of feet above the ground is moist enough to produce clouds and rain at the same time that the air closer to the ground is as dry as a bone. So when rain falls in these conditions it evaporates on its freefall to earth. It is easy to spot its wispy form seemingly hanging in the air beneath its parent cloud" Some Piccys Edited April 25, 2007 by Slapshot 3 Link to comment Share on other sites More sharing options...
timp Posted April 25, 2007 Report Share Posted April 25, 2007 v-i-r-g-a I think these weathermen try to sell it by email Link to comment Share on other sites More sharing options...
Andy Posted April 25, 2007 Report Share Posted April 25, 2007 v-i-r-g-a I think these weathermen try to sell it by email Glad I'm not the only one who mis-reads this every time I look at it Link to comment Share on other sites More sharing options...
gasserboy Posted April 26, 2007 Report Share Posted April 26, 2007 im no.155 cant wait! Link to comment Share on other sites More sharing options...
baldilocks Posted April 26, 2007 Report Share Posted April 26, 2007 183 getting nervous already Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
