feetupfun Posted February 15, 2019 Share Posted February 15, 2019 14 hours ago, nigel dabster said: always taken the stops off for trials applications same here Quote Link to comment Share on other sites More sharing options...
thai-ty Posted February 16, 2019 Share Posted February 16, 2019 On 2/14/2019 at 9:36 AM, feetupfun said: When I bought Boyesen reeds for TY175s and TY250s in the 2000s, the instructions said to fit them without the Yamaha limit plates. Are you saying that at some point in time, the limit plates were intended to be retained when you fitted Boyesen reeds? Current instructions for Boyesen reeds (2018) for ty Yamahas mention opening up the windows if you wish - normal Boyesen procedure (4 to 2 window?) and leaving the stop plates in situ. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 20, 2019 Share Posted February 20, 2019 pretty sure dual stage reeds dont have stops any bike? Quote Link to comment Share on other sites More sharing options...
pschrauber Posted April 1, 2019 Share Posted April 1, 2019 Yep they have an effect to the bike makes it a bit snappier, most effect you will get by using carbon fiber ones, be aware of replicas sold one E-bay for cheap not made by Boysen of bad qzulaity (I suggest not to use them). THe backdraw is price and they do wear not fast but after 500km on the speedometer mine had a bit fuzzy ends when looked ap through mangnifying glases. What is also a good idea to improve performance and so have more effect then the Boyesen: - using the cage and reeds of the TY250, (a bit of miiing is needed) - using the rubber inlet of teh RD 250, Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 13, 2019 Share Posted August 13, 2019 I've just done the opening up of a TY175 intake to take the original reed block out of my TY250, took a while with a dremel but less metal needed to come out than was needed to get the v-force reed block into the 250 What number reeds fit TY250 twinshocks? Boyesen's website show quite different numbers for 74 & 75 which is incorrect as they should be the same part, I suspect what they have for 75 is actually the mono but I can't confirm that Quote Link to comment Share on other sites More sharing options...
thai-ty Posted August 15, 2019 Share Posted August 15, 2019 On 2/16/2019 at 10:29 PM, thai-ty said: Current instructions for Boyesen reeds (2018) for ty Yamahas mention opening up the windows if you wish - normal Boyesen procedure (4 to 2 window?) and leaving the stop plates in situ. Correction the above was for a mono, not a twinshock, if i was confusing anybody. Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted May 18, 2021 Share Posted May 18, 2021 On 8/12/2019 at 5:22 PM, tony27 said: I've just done the opening up of a TY175 intake to take the original reed block out of my TY250, took a while with a dremel but less metal needed to come out than was needed to get the v-force reed block into the 250 What number reeds fit TY250 twinshocks? Boyesen's website show quite different numbers for 74 & 75 which is incorrect as they should be the same part, I suspect what they have for 75 is actually the mono but I can't confirm that Tony- did you get an answer on your question about the Boyesen reed part number? I am thinking of getting a set of Boyesen reeds for my TY 250 A and hoping it gives a performance increase, but the distributors do not seem to have a particular p/n that is a direct replacement for the OEM stock Yamaha reeds. They mention 3 different models and say they "might work" Quote Link to comment Share on other sites More sharing options...
tony27 Posted May 21, 2021 Share Posted May 21, 2021 Can't remember what the number ended up being but they're on the the reed block in the 175 now. The 6TR108 look more correct, seem to come up as fitting Fantic on Italian sites Quote Link to comment Share on other sites More sharing options...
