Beta Evo 4t 250/300
hey,
i've tested the 300 some weeks ago and liked it a lot; chasis and suspension are great
the bike feels light end nimble and gripps good
not so sure about the engine, it seemed a bit flat in low revs, i found it reacts a bit slow when giving it some gas comp. to my sherco 4t
but in total a great bike
  • Replies 79
  • Views 64.6k
Most Popular Posts
  • Rode my 300 sunday seems a bit flat off the bottom not sure its rich, mine has a 120 main fitted. I think they have a very little ignition advance at low rpm, seems to grip better and the chassis/hand
  • fivemeister
    fivemeister
    What, they controlled the propulsion of the bike using a small two position rocker switch situated under the tank?
  • I only made the comment as programmable traction control seems to defeat the whole purpose of trials.
The bike has duel stage mapping - a relaxed affair for mud etc and a second more immediate aggressive response - at the flick of a switch.
When I was a lad that was called a throttle.
No, but the ability to adapt to different conditions was rider controlled rather than rocker switch, it was part of the fun.
It still is - no less so for the mapping feature which is no different to other major improvements such as better designed suspension, lighter materials, tyre technology et al.....
I also own and ride 80's bikes (240 fantic / ossa MAR) and enjoy them for what they are. I just enjoy riding my duel stage mapped modern bike the mostest.
Edited by Fivemeister
I cant wait for ABS and traction control, some of the other "improvements"
You are just being argumentative, anti modernist and plain luddite. Such issues will always have to be regulated as material and production technology has overtaken most sports (especially motor sports, but generally ANY sport)
Just think of the good old trials tyre - don't you think that one of the manufacturers couldn't have produced a more efficient shape / design / construction if they hadn't been restricted?
Anyway, back to the thread - its about the Beta evo 4T - not a curmudgeonly rant about modern technology.
Agreed, its just that change doesnt = improvement.
Agreed, change doesn't always = improvement, however, no change = no improvement.
Thats not what it is and you know it.
The switch merely alters the engine response characteristics to suit the rider or conditions. Its no different to tweaking your bike with a slow throttle / flywheel weight or ignition timing etc etc. Its something riders have done to their bikes since year dot, except that now technology makes it easier - thats all.
Riders will still have to find traction using their skill, no matter how the bike is set up.
Anyone checked / adjusted the valves yet? I understand that on the REV4 you had to tilt the engine forward - what's the story with the EVO? Anyone have clearance spec?
Sure looks like there is more room, with the EVO. At least enough to get to the exhaust side, maybe.
How often do you need to adjust / check the valve settings?
What symptoms do you get if they are wrong?
If they are set how do they change?
