My 90's Gas Gas Contact250 Project..
If you are already planning on a strip down, powder coat and rebuild after it fires up, you may be farther ahead just biting the bullet and tearing her down now and starting from scratch.
  • Replies 186
  • Views 38.8k
Most Popular Posts
  • J if it were me I would check out reed block up-turn and dump any fuel that has got into the crank heat up a good plug and maybe a squirt of easy start. failing that....... go for a beer ;-]
  • thats_a_five
    thats_a_five
    You say you turned the bike upside down and "a fair bit of fuel came out." Just to be clear, there will be fuel that comes from the carb bowl. That is not a problem, it is just the bowl draining.
  • Check the stator and HT lead then. Although your spark appears ok when out and against the frame the spark is only under atmospheric pressure, when under compression the stator may not be producing th
Problem is I do not want to chuck money into to then realise the engine doesn't run good, suspension needs rebuilds etc. so just want it running and going to try it for a few days and then go all out.
Rather than waste £100's on it and still have a bike that doesn't run and needs an expensive engine etc
Was hoping to be off work today as I have been all week (joys of working offshore!) but I'm going out today :( gutted.
Hopefully some late night progress tonight :)
Keep us posted.
Trust me, you will be very happy the first time you hear it fire up after all the fiddling you've been doing. It's a great feeling. If you don't smile or laugh out loud even, I would be very surprised :D .
Back home from work already. I love this job haha,
Going to try get the kick start together and get the carb back in and hopefully will be running after an hour or too worth of of work! :)
Aft another 50 minute drive to get another kick start (super thin light alloy again :( lol) fitted that.. Went to kick over and the back of the kick start catches!! Again.. I managed to laugh it off.. Spent an hour filing it down so it now clears the frame..
So... Kick start is on.. Carb is rebuilt and on.. New fuel and oil.. New spark plug..
I don't dare try it! Haha!
Here goes.. Watch this space! *please start*
Grrrrr!! I have spark, I have fuel.. Why the **** is it not starting? :(
my mates bike 'peter the beta' was refusing to start - fuel? - check, spark? - check.............. scratch head time............ heated up the plug with a blow torch................ zilch, nada.
too much fuel?? we ended up turning the bike upside down, with plug out, turning it over to empty the crank of petrol...................... right way round, plug in and ring-a-ding-ding!
try it.
How would you know your getting too much fuel? After a few minutes of kicking the plug is wet? Clean clear fuel?
Will try that tommorow.. I'm about at my patients limit at minute :(
I'm not in a position financially to be able to book it in a shop for investigation as I have just changed jobs and haven't been paid for 6 weeks :(
if you have flooded it a few times, left fuel on with dodgy float level etc.................. it doesn't take much to really flood the thing so it wont start.............. well, that was our experience with the beta.
Hey guys, some of you may have seen in my project thread I'm having problems getting my Gas Gas contact 250 (1994 ish) figured I stand more chance of getting ideas on here rather than my small build thread..
After rounded of kick start splines, choke levers snapping, new kick start snapping..
I finally have the bike so it kicks over!
I have spark, after a good few kicks the the plug is wet when removed.. Have tried choke on/off. Covering part of inlet, throttle a little open, fully closed.. Staying brake cleaner into carb while kicking..
Nothing! I have been told to turn it upside down to try drain any fuel in crankcase out of the spark plug hole..
Anything else worth trying? I'm kicking it over as shown in the video.. Kick it gently so it just passes TDC then give it a good strong kick (using my weight not leg muscle)
Thanks..
Also forgot too add, it hasn't been run for 6-7 years, carb has been cleaned, jets all clean, fresh fuel, new plug gapped correctly..
Will give it a try tomorrow. I can't remember if the fuel tap was left on over the years or not! The floats are nice and free and not filled up so should be working properly.
If any of the earths/connections electrically were a problem it wouldn't spark would it?
Do you ever ride Corton Trials Park?
Ok, was hoping to be able to reach people outside the GG forum too as I'm totally out of ideas now :(
I havent been there, but plan to........... I have only had a trials bike since last september, so its still early days............. I have emailed the owner and he has explained the set up there - it sounds really good.
if the bike was running when you last used it and you have been round the bike and checked it, then logic tells me that it isnt going because of the whole fueling issue...... reed block assembly isn't glued up as well is it?
