Psi Newton Meters Conversion
I need to re torque the cylinder head on my 350 77 Sherpa
the manual give a torque setting of 15 PSI can any one tell me what this is in Newton meters ? confused of Javea
1 pound-force inch (lbf-in) = 0.1129848 newton meter (Nm)
0r
1 newton meter (Nm) = 8.85075 pound-force inch (lbf-in)
MMMMMmmm! I'm confused! Does the PSI stand for pounds per sq inch? If so, thats a measurement of pressure and Newton Metres is a measurement of force.
You can do PSI to Newton/Square Metres. Is there such a thing a table or chart that gives psi in Nm???
What is the diameter and thread of the fastener and is it into aluminium?
Mags
They probably meant to say foot pounds but it came out PSI. I wouldn't suspect that they have torqued the head at 15 in pounds.
Keep in mind that this is probably a Spanish manual translated by a buddy for a case of beer.
--Biff
PSI has got nothing to do with torque.
My Bultaco manual (from InMotion) states 12 ft.lbs which is 16 Nm
Thanks for the replies afrer a "caja de San Miguel" it has become clearer in my head as guys posted 12ft.lbs it is then stocking up on " inspiration fluid SM." before i check my Tyre pressures :beer:
The ideal gas mix for your tyres is 78% nitrogen, 21% oxygen, 1% water... if you can find that mix locally?
Mags
If i fill the front tyre with 100% nitrogen will it be easier to wheelie ? and also if I lose control over rocky terrain could I then breath in the nitrogen from the inner tube to ease the pain ? :unsure:
No, the difference of only 4 Molecular Mass M (kg/kmol) is not enough, you need to use Helium of course! :rolleyes:
