New Suzuki Beamish Rl250 Project
Just got this Suzuki rl250 trials bike, from what i understand it is a 1976 model, the bike has a sound engine and no nasty suprises, only problem i am having is with the front brake, no matter how i adjust the brake it seems to slip under pressure, the shoes seem fine but i have heard the front brakes on these were not great anyway.
  • Replies 33
  • Views 20.7k
Most Popular Posts
  • Hello, I am probably wrong but I think those fork clamps/yokes look like the type fitted to the Beamish sidecars. If so the geometry may be slightly different to suit a sidecar. Hope this is helpful
  • I did mine a few months back  -  living hell...   I don't think there is a way of pressing them out.   I drilled through the rubber section, all around the inner steel tube of the bush on both sid
I had one that year, from memory the brakes were as good, or bad, as anything else of the period. Could try chamfering the leading edge of the lining material with a file to make the brake as effective as possible.
The problem seems that the shoes are pulling open and just as ther biting the piece inside the drum that opens the shoes is slipping, ive ordered new brake shoes to see if that solves the problem but would like to just try and change front wheel all together as my one is buckled
Was trying to work out what fork clamps these are, have never seen them on a suzuki and not sure where they have come from
Quite nicely fabricated, one off set maybe?
Ok so done a trial on it sunday just gone and i think ive got more work ahead of me than anticipated, the forks were bottoming out so would like to try and source some heavier springs perhaps? The front brake is still rubbish and the front wheel is buckled so would like to try getting the wheel refurbed and brake relined, will change throttle for a domino one as mines quite heavy and the rear brake pedal is off a road bike and isnt very nice to use. Oh and the rear frame loop has cracked where its previously been welded
Make sure you have the correct pre-load spacers in the forks, they should be quite long
I use NJB rear shocks on my beamish
  • 1 month later...
  • 2 months later...
Sorry for late reply but i agree this may be the reason, i have just bought a later frame with the original fork clamps so i am going to use them instead
I heard that as well, apparently a 78 rm 125 wheel fits but as always its a case of finding one which is easier said than done
