November 1, 201511 yr Hi guys, Just bought a 1979/80 198 A 250, it has electronic ignition. I've bought a new spark plug which I've been advised needs a gap of 0.4mm, but when I ordered it I didn't say it had electronic ignition. Is there a different gap setting for each. Also the bike runs and starts well on choke but dies when the choke is turned off. I've had the carb apart and found 150 main jet. 20 pilot jet. 3 slide. 2b1 needle 106 main jet. I've had carb cleaner through each and every orifice, because I thought it would have been a blocked pilot jet. The previous owner has owned it for years but hasn't really used it for a few years. I've drained and flushed the tank and got new fuel mix at 50:1 with synthetic oil. But it runs fine on choke and then dies. Am I missing something obvious ?????? Many thanks.
November 1, 201511 yr Checked carburettor rubber union for leaks/properly tightened? Could bind with insulation tape as a quick fix to check if this makes a difference.
November 1, 201511 yr So it runs when it's rich (I.e. With choke on) - agree with cleanorbust sounds like an air leak..
November 1, 201511 yr Author Thanks , with it being stood for so long it may be the crank seals that have failed, or at least the flywheel one as it's not smoking. I'll start looking for an air leak. Any views on the plug gap for electronic ignition, or is it the same as standard?
November 1, 201511 yr Hi Chappo, before you start pulling it apart to do the seals, are you absolutely sure that the jets are clear? Sometimes they need a careful poke with thin wire to clear an obstruction.
November 2, 201511 yr electronic ignition supplier should tell you what gap to use, but there will be no harm done using 0.4mm. I use 1.0mm plug gap on my bikes that have modern aftermarket electronic ignitions.
November 2, 201510 yr The recommended plug gap for the CDI on my Sherpa is 0.7mm. This is the one from a well known English Bultaco shop. Graham.
November 2, 201510 yr I would go along with 0.7, any larger and you are more likely to get a spark on the outside of the HT lead or HT coil when its wet. Electric takes path of least resistance
November 2, 201510 yr Hi Chappo, I imagine it has an Amal carb?? What you are describing is a blocked pilot as Pigbog mentions, I am no help when it comes to Amals but if you have access to another carb??? As to seals; very unlikely in my experience. Have a nice day Larry
November 2, 201510 yr Author Thanks gentlemen, That gap info is great, not taken the flywheel cover off yet so not sure of the manufacturer. Larry, yes my mistake it is an Amal 2600 series 2 concentric. Ordered a new float and associated jets, the jets that Amal have on their records as being correct for the bike are the ones that are in. Going to have it sonically cleaned then fit the new jets and go from there. Will update with progress later in the week. Regards, Dave.
November 2, 201510 yr Hy Chappo I think the slow jet 20 is wrong, should be about 42 or 45. Would explain, why it only runs with the choke. New jets are always to recommend. Make sure ab out the original size, can maybe deviate 1 number, if different air box is fitted. don't think the 4 or 7mm makes a big difference, but 4mm seems to be good (used on my Sherpa M49 250cc with new electronic ignition) good luck, Pat
November 2, 201510 yr The jets you have listed are correct for an amal on a 198A. Amals are notorious for wearing out the slide and the needle '2B1' and the needle jet '106'. The bike will start easily and run ok until you try to rev the bike then it will splutter and carry on a treat. No amount of messing with the mixture screw or moving the needle will fix it.I am not sure this is what yours is doing but the needle and needle jet should be replaced before you do anything.
November 3, 201510 yr Author Thanks Sherpa 325. Mine starts a treat runs smoothly on choke, but not that fast, you then turn the choke off and it dies. New needle and full set of jets on order. Thank you.
November 3, 201510 yr Throw the Amal carb in the bin and replace with a new mikuni carb is a good way to go i really wouldn't bother wasting money on new jets. on a old tired Amal carb.
November 3, 201510 yr Author Thanks Bondy, Seen your Sherpas on here, is that what you have on yours, the Mikuni replacements? Jets have arrived today, just want to try and get it ready for a first outing this Saturday. After that I'll look at the Mikuni options. Edited November 3, 201510 yr by chappo
