Wes Alloy Clubfoot
10 hours ago, sherpa325 said:
All the blue plastic tanks I have seen have had the two captive 6mm nuts in the plastic that the tap is attached to, the red199 tank I am pretty sure has a 12mm thread
PS I have no idea what tap fits the UK alloy tanks, but I assume they are UK only?
Cheers Greg
apologies i meant the tank to frame fixing not fuel tap!!! Yes fuel tap is 6mm, correct.
  • Replies 62
  • Views 22.6k
Most Popular Posts
  • shercosteve
    shercosteve
    I have purchased one from Inmotion this week and is on the way to the US, full report soon ! Hoping for weight loss over stock, nice sound and any performance gains would be nice, plus its rebuildable
  • smelling123
    smelling123
    Did you get a reply model80? It'd be good to know weight too.. I'd consider one of these, I did my own version to save weight but these look good, might be tempted..
  • I had a look at the WES website yesterday, but nothing was listed, so I emailed enquiring about availability and price. Will let you all know when I get a reply. I will more than likely anodise or pa
"PS I have no idea what tap fits the UK alloy tanks, but I assume they are UK only? "
The aluminium tank I bought in the UK has a M12 thread for the tap.
Weren't aluminium tanks mandatory at the time in the UK (only), to replace the polyester tanks that were prone to crack? Before the nylon tanks came out.
There are a couple of taps that fit the original tank, two of mine have early model Sherco taps which have the same bolt spacing and I just realised that the tap I purchased off inmotion has a detachable 12mm threaded part, that screws into a block that has the two 6mm holes, so it looks like it would fit the earlier style fitting, so in effect it would fit both styles of tank.
PS I would check with them first as I don't have an earlier tank to test this out on.
Edited by sherpa325
