Fantic Section
 Coolant for aluminum blocks ok. The fan is worn, lubing won`t help. Make sure the thermo is bypassed and you can push start it with your fingers. Most fans will fit it. It should take closer to 300 ml, but I cannot remember exact amount. A bit of piston slap is most of it.
  • Replies 85
  • Views 29.7k
Most Popular Posts
  • whitehillbilly
    whitehillbilly
    Changed the coolant, 500 mls. Good weekend trial, 40 section day, Fantic ran like a dream, apart from hand starting the Radiator fan, now and again. Took my 10 year old daughter for the first time,
  • whitehillbilly
    whitehillbilly
    One of these.
  • whitehillbilly
    whitehillbilly
    Well Santa has packed his Sleigh away for another year. All ready to go. First Trial Kicks off next week.
Thanks for the reply.
I am wanting to fit a side stand.
Noticed a recess and allen bolts in the swingarm.
Anyone got a close up of one fitted.
How thick is the bracket ????
thanks
whitehillbilly
The top of the front forks, has a knob on the right, which turns.
A valve on the left.
If I change the fork oil, how do I reset things ????
Thanks.
Whitehillbilly
Just had another look and the one on the left isn't a valve. Its a square 10mm nut.
whitehillbilly
The nut adjusts the spring preload.
My Fantic Section had an overheating problem which caused pinging. I found out that the old hoses got soft and the one at the pump on the suction side would squeeze itself shut. I replaced it with a metal gas water heater hose.
Thanks.
Is the gas hose, the stainless steel braided type, and where did you get it from.
One of the hoses seems to touch around the exhaust..
To change the fork oil is it simply drain, remove the top nuts, fill and replace nuts, or you you need to Dow something to the two adjusters on the top ????
Whithillbilly
Edited by whitehillbilly
Can anyone confirm the flywheel puller thread.
32-1.25 has come up on a search.
So did 32-1.0
Thinking of getting one made, as my mate around the corner has a lathe.
Thanks
Whithillbilly
A coolant question.
Is it easy to change, and bleed ????
How much coolant is needed, and what level do you fill it to.
Thanks
Trial, Sunday and I hope to give it a run.
whitehillbilly
Took my 10 year old daughter for the first time, and was asked why I wasn't in uniform, like the others. :lol:
First pic is my uniform. Then it warmed up a bit.
  • 3 weeks later...
