cascao Posted November 18, 2016 Report Share Posted November 18, 2016 (edited) We will have a hard enduro at nigt here next month. Can I put a 35W or 55W halogen light in my Sherco ST300 2015? Or there something else beside bike battery powered lights? (will use in my helmet) Edited November 18, 2016 by cascao Link to comment Share on other sites More sharing options...
michael_t Posted November 18, 2016 Report Share Posted November 18, 2016 are you saying the standard light is not powerful enough for night riding? - LOL I use 400W light to lighten up my backyard to practice this time of year. Link to comment Share on other sites More sharing options...
jonnyc21 Posted November 18, 2016 Report Share Posted November 18, 2016 (edited) Not sure if your in the US or not so timing and/or import tax could be a consideration if your not for at least cyclops. But then again cost is also a factor... Here would be my vote. Helmet lighting: http://www.cyclopsadventuresports.com/-Cyclops-Racer-LED-Helmetlight-kit-_p_154.html On bike: https://www.bajadesigns.com/products/onx-motorcycle-light.asp Edited November 18, 2016 by jonnyc21 1 Link to comment Share on other sites More sharing options...
reggie Posted November 18, 2016 Report Share Posted November 18, 2016 I think an LED light would give you lots of light without taxing the magneto too much. I think 55w could be an issue with the magneto lighting windings. Link to comment Share on other sites More sharing options...
michael_t Posted November 18, 2016 Report Share Posted November 18, 2016 I think it is worth going with a helmet light if you are riding rough trails. Better to have the light pointed where you plan on going instead of where the bike headlight may be pointed, this especially noticeable when you wheelie it is great for lighting up the trees but I find it better to be able to see what you are actually headed for... 1 Link to comment Share on other sites More sharing options...
dan williams Posted November 19, 2016 Report Share Posted November 19, 2016 I bought an LED bulb from the discount bin for 12V lighting systems just to see if it would plug into my Beta's headlamp and work and it did but I never completed the project. I've been thinking it might be kind of interesting to layout a PC board as a number plate and populate it with bright white LEDs for night riding. Wide area on some and some narrow beams going forward with a few pointing down for wheel lifts. The Beta system is 85W which is a lot of light with LEDs. Something to do in my spare time this winter I guess. Link to comment Share on other sites More sharing options...
copemech Posted November 19, 2016 Report Share Posted November 19, 2016 I have some older tech data on the Leonelli systems that indicate 110W output. Not sure what the newer ones will do from Hydria or whomever.. Link to comment Share on other sites More sharing options...
jonnyc21 Posted November 19, 2016 Report Share Posted November 19, 2016 Aren't some of the systems AC and need DC conversion to work correctly? Not that it's hard to do that but I wonder how much that affects creating something like that Pc board number plate? Link to comment Share on other sites More sharing options...
stpauls Posted November 19, 2016 Report Share Posted November 19, 2016 Some of the pushbikes that I see on the way to work have incredibly bright lights. Don't know anything about them though. Link to comment Share on other sites More sharing options...
guys Posted November 19, 2016 Report Share Posted November 19, 2016 (edited) For slow speeds, mountain bike lights might suffice, I've used them on a night trial event (one on the handlebars and one on my helmet), not sure that they're suitable at the higher speeds that are ridden in enduro though. Edited November 19, 2016 by guys Link to comment Share on other sites More sharing options...
dan williams Posted November 19, 2016 Report Share Posted November 19, 2016 Rectifying the ac is pretty simple and stabilizing the voltage is pretty easy too. Also want to make sure there is sufficient current to start the fan when it needs to. Induction motors need a pretty big kick to get going. Making sure the LED die don't get too hot is the real problem. The high output LEDs are usually on an aluminum backed PC board for cooling. There are quite a few places that will do a small run of PCBs for a few hundred dollars. Link to comment Share on other sites More sharing options...
michael_t Posted November 19, 2016 Report Share Posted November 19, 2016 I suppose if you wanted to get really fancy you could use a self leveling camera mount to keep the light pointed in the right spot and dampen it so it doesn't bounce all over the place... a fun winter project. Link to comment Share on other sites More sharing options...
cascao Posted November 20, 2016 Author Report Share Posted November 20, 2016 ....but my hidria ignition will put how much power? Scared of burning the coil if I drain too much... Link to comment Share on other sites More sharing options...
guys Posted November 21, 2016 Report Share Posted November 21, 2016 Why don't you send Sherco a mail to ask them? Link to comment Share on other sites More sharing options...
cascao Posted November 21, 2016 Author Report Share Posted November 21, 2016 (edited) Ok, will try mailing Sherco. Thanks everybody Edited November 21, 2016 by cascao 1 Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
