oldaz Posted March 9, 2018 Share Posted March 9, 2018 Almost finished rebuilding my VUK and finally got to TRY and install the kickstart return spring I got from Inmotion. Problems are, the hook that goes in the notch in bottom of lever is level with the pin that goes in the case - so the spring has to be "wound up" half a turn (180 degrees) to get it in there - if this is even possible. Second problem is IF I ever get it in there, when I operate the kicker it will load the spring another 180 degrees which seems way too much tension - I don't think the spring would last long this way. Does anyone know the correct method to fit the spring? Quote Link to comment Share on other sites More sharing options...
keychange Posted March 9, 2018 Share Posted March 9, 2018 The spring has to have some loading on it otherwise it will flop around. The kick start is usually installed at around 2 o'clock rather than vertical. I have only had one spring break and that was when my son tried starting with the clutch in Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 9, 2018 Share Posted March 9, 2018 Have replied on Trials Australia Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted March 9, 2018 Share Posted March 9, 2018 How I attach my spring: Fit spring into notch on kickstart lever. Insert straight end of spring into hole in flywheel cover. Rotate kickstart to correct angle (only about 45 degrees counter clockwise) Push kickstart on to splines and tighten pinch bolt. Quote Link to comment Share on other sites More sharing options...
turbofurball Posted March 9, 2018 Share Posted March 9, 2018 56 minutes ago, cleanorbust said: How I attach my spring: Fit spring into notch on kickstart lever. Insert straight end of spring into hole in flywheel cover. Rotate kickstart to correct angle (only about 45 degrees counter clockwise) Push kickstart on to splines and tighten pinch bolt. Same here, though I got my lever at about the 11 o'clock position (with the hope that it might reduce the chance of putting a hole in the engine again, lol) Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 9, 2018 Share Posted March 9, 2018 2 hours ago, turbofurball said: Same here, though I got my lever at about the 11 o'clock position (with the hope that it might reduce the chance of putting a hole in the engine again, lol) How do you avoid banging your shin on the lever while riding sections? Quote Link to comment Share on other sites More sharing options...
turbofurball Posted March 9, 2018 Share Posted March 9, 2018 It doesn't stick out much, I've not noticeably caught it so far Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted March 9, 2018 Share Posted March 9, 2018 3 hours ago, turbofurball said: Same here, though I got my lever at about the 11 o'clock position (with the hope that it might reduce the chance of putting a hole in the engine again, lol) You do mean 11 o'clock, not 1 o'clock? The position in keychange's photo looks correct and wouldn't damage the casing Quote Link to comment Share on other sites More sharing options...
turbofurball Posted March 9, 2018 Share Posted March 9, 2018 Oh, yes, I meant 1 o'clock ... that was a typo, lol It's noticeably further up than in the photo, anyway Quote Link to comment Share on other sites More sharing options...
potto Posted March 9, 2018 Share Posted March 9, 2018 Interesting...I have very little preload on the spring but when I move the lever around towards the starting position the spring loads up,lever returns back to rest fine. I don't know if its correct by the book but it functions as it should ,was that way when I got the bike. Quote Link to comment Share on other sites More sharing options...
oldaz Posted March 10, 2018 Author Share Posted March 10, 2018 Got a response and pictures from Pete at Inmotion. The first thing I noticed was in one picture it shows the hook end of the spring hooked around the bottom of the kickstart lever and the hook has a slight twist to allow it to fit right in there. The end of my spring wasn't twisted like this and didn't fit right in the notch, so I modified it to fit the same way. That gave another few degrees less tension and although I believe it's still more than needed I can now get the lever on there. My original spring was broken and part of it missing, so I had nothing to go by, now it makes sense. Thanks for all the responses, with the help from all of you, I might get this thing finished. 2 Quote Link to comment Share on other sites More sharing options...
oldaz Posted March 11, 2018 Author Share Posted March 11, 2018 12 hours ago, oldaz said: Thanks for all the responses, with the help from all of you, I might get this thing finished. Here's a picture of the nicely re-chromed kickstart now in place and working fine and theoretically that's the last of the mechanical bits. Started on fibreglass repairs to the tank/seat unit, already got the 2k paint for it and first lit of fibreglass applied. Need to get some primer filler for the little ripples/scratches next. 4 Quote Link to comment Share on other sites More sharing options...
Montesa66 Posted April 9 Share Posted April 9 Anyone working on or have knowledge about a 1966 montesa with kickstarter on left side ( sitting on the bike) . Trying to replace spring can’t see original, or where it should be. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
lemur Posted April 9 Share Posted April 9 17 minutes ago, Montesa66 said: Anyone working on or have knowledge about a 1966 montesa with kickstarter on left side ( sitting on the bike) . Trying to replace spring can’t see original, or where it should be. Any help would be greatly appreciated. Post up a picture of this rare motorcycle. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted April 10 Share Posted April 10 18 hours ago, Montesa66 said: Anyone working on or have knowledge about a 1966 montesa with kickstarter on left side ( sitting on the bike) . Trying to replace spring can’t see original, or where it should be. Any help would be greatly appreciated. Are you sure it's a Montesa? Quote Link to comment Share on other sites More sharing options...
