TY 175 rebuild
trialsrfun
Am assisting with the rebuild of a TY 175 which when completed will be ridden in trials including the KIA series. What is the best set up for the frame and forks please, can the skinny leg 175 forks be made to work well, they operate smothly enough but seem very softly sprung with not much damping. The frame is totally standard what changes or improvements could be made to improve steering, handling, footrests etc or is it best left alone? Chain is 428 with 12t gearbox and 51t rear wheel sprockets fitted are these sizes a good choice, needs work before it can be ridden.
Edited by trialsrfun
I built my TY for proper competition use, despite being a heavy and unskilled rider.  It's a joy to use.
Going full Majesty with the frame makes sense if you can afford it, or just tidy it up and make the changes to the original frame (which is what I did - heavier, but behaves the same) - moved the shock mounts, removed the oil tank mounts, added gussets, tidied the steering stops, removed the forward peg mounts, lengthened the swingarm.
Bolt-on relocated footpegs are fine, but you need to tweak the brake pedal to match otherwise it's unusable.
The skinny front forks can totally work, chuck in Magicals springs and then play with oil weight and the spacers to tune it to the rider (mines pretty much spot on with 10w oil and the stock spacers).
A set of decent shocks at the back should balance the front out nicely, their specs will vary depending on where you put the shock mounts.
I invested in yokes that steepen the fork angle too, this makes it tiring for trail riding (too twitchy at speed) but super for trials.  Also, a stainless downpipe and Wes exhaust saved a LOT of weight.  Bone stock my TY was 84Kg, now it's around 80 despite adding material to the frame.
I have 12/51 gearing IIRC, and do 95% of my riding in 2nd gear.  It works well, but I'm thinking of going to a flat slide carb to go with my new big airbox for more low end torque
  • Like 2
  • Thanks 1
These skinny fork tubes works well but are flexible and in a slightly harder crash they simply bent.
I had my first crash with them in 82 in to get new stanchions wasn't a problem. Now its much more complicated.
What you can do is swap to a TY 250 fork with holes or a TY 250 mono forks, both works fine, I stil thing the mono works even better because of its overrun and I done it to my TY.
The rear shocks can be replaced to better.
A really good thing is to extend the swing arm 30mm, you need a new brake arm then too. I have made a CAD drawing for that so the longer arm can be cutted by laser and have likewise holes like the originals.
Mounting the engine reed cage of the 250cc model is a good fix, too get rid of all internal stuff of the airbox to get better breathe.
If you come along a 175 MX clutch case from 74 and 75 that is too an improvement then you got rid of the oil pump and it's casing too.
  • Thanks 1
Will a flat slide carb give more low down torque. I thought they were better for top end ?
The Mikuni VM is good and works good, you can replace it against something different but be aware that it will be costly to find the right jetting, needle and needle valve.
The the flat slide carbs can give a slightly better Performance but these are more picky about the right  adjusting and jettingh then old style round slide carbs.
I fitted a 26mm OKO carb to my 250 Bultaco Sherpa model 124 to replace the oiginal 27mm Spanish made  Amal concentric which was totally worn out. I carefully followed this tuning guide http://www.mid-atlantictrials.com/Instal.html  and the bike now runs very smothly and cleanly all through the rev range, unsure if there is any more bottom end but it runs nicely which makes it easier to ride. As I understand it getting an OKO with the right choke diameter is critical then playing about to find the best pilot jet. There is a lot of OKO info on the weblink above and buy genuine not a copy from an auction site.
  • Like 2
On 17/03/2018 at 9:36 PM, feetupfun said:
Rider weight? Rider size? Motor standard? Rider skill level?
It is staying a 175, the other questions I will let him come here on tc and give that info himself, should he not then maybe we will make something up eh!!!:P
I have (the wrong size of) OKO on the Montesa, once teething issues were sorted (many air leaks in the engine, intake pipe, float level wrong etc) it's been working well and wasn't hard to get running right :)
  • Like 2
Quite a lot of interesting ideas. TrialsRfun is assisting me with the ty175 build.
So far I have got ty250 fork to go into it just getting them rechromed. Also on the way is dual stage electronic ignition and and I will be trying  on oko flatslide on it.
  • Like 2
  • Thanks 1
It's probably not worth going to an OKO unless you're changing the air box and exhaust BTW, the original carbs are very good at what they were designed for ;)
If the slide isn't completely worn out, that is.  Not an uncommon problem out here in the wild, wild west, but YMMV.
