b40rt Posted November 23, 2019 Share Posted November 23, 2019 7 hours ago, feetupfun said: I've heard there is also lining material designed to work on brakes that operate under water and that this material works well on trials bikes (that often have wet brakes) but I haven't tried it yet This material actually works best (IMO) when it is wet, its only negative is it can be a be grabby when feathering the front brake. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 23, 2019 Share Posted November 23, 2019 @dozerash, have you read through the many posts that appear earlier on the swm forum ? All the info is there about clutch springs, adjustments, leavers etc Have you extended the arm inside the clutch casing ? An all day one finger clutch is possible without using hydraulics. 1 Quote Link to comment Share on other sites More sharing options...
dozerash Posted November 25, 2019 Author Share Posted November 25, 2019 On 11/23/2019 at 4:37 AM, b40rt said: @dozerash, have you read through the many posts that appear earlier on the swm forum ? All the info is there about clutch springs, adjustments, leavers etc Have you extended the arm inside the clutch casing ? An all day one finger clutch is possible without using hydraulics. I have been reading them. A lot of info! Thanks! I have a newer style clutch cover from a Can Am that has the bigger actuator balls. I’m going to try it this winter. I noticed the other day my bike is leaking oil from the Kickstarter/shifter area. It leaked a couple of years ago and I replaced the seal and o ring. I will replace them again when I install new cover. Quote Link to comment Share on other sites More sharing options...
dozerash Posted February 28, 2020 Author Share Posted February 28, 2020 I remember someone posting that a good set up on my 1980 SWM 320 with Marzocchi forks is to keep the Marzocchi triple clamps and use the Betor forks? I realized that my spare/project 1980 SWM 320 has the Betor forks and triple clamps. Would it be worth it for me to put the Betor forks (after I go through them) on my competition bike with the Marzocchi triple clamps? Quote Link to comment Share on other sites More sharing options...
dozerash Posted February 28, 2020 Author Share Posted February 28, 2020 (edited) I noticed my front brake arm on the brake hub seems short, would it help to lengthen it or find a longer arm? Edited February 28, 2020 by dozerash Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 28, 2020 Share Posted February 28, 2020 7 hours ago, dozerash said: I noticed my front brake arm on the brake hub seems short, would it help to lengthen it or find a longer arm? @midlife. Give the man the benefit of your infinite wisdom. Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 28, 2020 Share Posted February 28, 2020 7 hours ago, dozerash said: I remember someone posting that a good set up on my 1980 SWM 320 with Marzocchi forks is to keep the Marzocchi triple clamps and use the Betor forks? I realized that my spare/project 1980 SWM 320 has the Betor forks and triple clamps. Would it be worth it for me to put the Betor forks (after I go through them) on my competition bike with the Marzocchi triple clamps? The 1980 Marzocchi's (imo) were not the best, check the betors are the same length, they are reckoned to be better. Whether you use the betor yokes probably depends on your height. If your taller than 6ft, I'd go for the Marzocchi's. Quote Link to comment Share on other sites More sharing options...
pschrauber Posted February 28, 2020 Share Posted February 28, 2020 (edited) The Marzocchies are not bad forks they work quite good it is all about the wear and how straight the stanchions still are. Gilles Burgat started to replace the Marzochi front fork of his 1980/81 SWM because of two reasons: - the Betor fork at less stiction and - the Betor is a shorter in length and the Marzocchi forks a a bit longer too the yokes | triple clamps mount is a bit higher then to them of the Betor fork. Thus the front will be slightly lowerd which will put some extra weight to the front wheel. With more weight at the front the (in my experience in our sand sections) bad behavior of the SWM pushing the front wheel straight while doing a tight turn with slight throttle is then in my experience a bit eliminated, for our super techical and thight sections on loose ground very helpful. Edited February 29, 2020 by pschrauber Spelling and Sentence issues fixed Quote Link to comment Share on other sites More sharing options...
dozerash Posted February 29, 2020 Author Share Posted February 29, 2020 18 hours ago, b40rt said: @midlife. Give the man the benefit of your infinite wisdom. ? Quote Link to comment Share on other sites More sharing options...
dozerash Posted March 1, 2020 Author Share Posted March 1, 2020 On 2/28/2020 at 3:17 AM, b40rt said: @midlife. Give the man the benefit of your infinite wisdom. ? Quote Link to comment Share on other sites More sharing options...
dozerash Posted March 1, 2020 Author Share Posted March 1, 2020 Here is the brake set up on my 1980 TL320 competition bike. Quote Link to comment Share on other sites More sharing options...
dozerash Posted March 1, 2020 Author Share Posted March 1, 2020 Here is the brake set up on my 1982 TL320 spare bike. Quote Link to comment Share on other sites More sharing options...
dozerash Posted March 1, 2020 Author Share Posted March 1, 2020 Here is the front brake set up on my 1980 TL320 project bike with Betor forks. Quote Link to comment Share on other sites More sharing options...
basinbaker2 Posted March 6, 2020 Share Posted March 6, 2020 I have done this switch on my 320, I have marzochi yokes with betor stanchions. 1, The marazochi yokes have handlebars mounted closer to the centerline of steering axis, so steering allegedly feels quicker ?, not sure I've felt the effect but hey!. 2, the Betor stancions are about 25mm shorter than the marzochi, so again pulling in the front overhang and quickening the steering feel. Ps the Fantic marazochi yokes have different bearings, and hence a different stem in the yokes. Quote Link to comment Share on other sites More sharing options...
dozerash Posted March 7, 2020 Author Share Posted March 7, 2020 I might try the Betors off my spare bike, I will need to install a new fender and fork seals. I guess my SWM could turn a little sharper. Might help my results. I just wish I could find a spare set and not take them off the other bike. Quote Link to comment Share on other sites More sharing options...
