October 21, 20188 yr I've been trying to practice figure of eights on a TLR200 and especially in 2nd gear I find the power delivery very jerky, it's almost like the power is off or on, not at all smooth. It's better in 1st but not what I'd call pleasant, are other TLR's like this or is it the carb ( or just me )?
October 21, 20188 yr Yes they are like that, you could try lowering the gearing slightly as they are very snatchy off the bottom end.
October 21, 20188 yr Hi Check the final drive sprocket see if the layshaft it sits on is worn . It will always be snatchy if it is.
October 21, 20188 yr If it’s better in first than it is in second it could be the rear wheel sprocket needs to be bigger or maybe a tooth off the gearbox sprocket might help. Get the carburation set up to eliminate any rough running, small engines...it’s only a 200 so shouldn’t have much effect upon slow riding!
October 21, 20188 yr The standard gearing on TLR is too high - put a smaller front sprocket on and second becomes much more tractable and manageable - in fact first is only for slow down hill descents
October 22, 20188 yr Author I've just checked my gearing and it's on 9/46, should be ok? I'm going to ultra sonic clean the carb and see if that helps, thanks so far.
October 22, 20188 yr 2 hours ago, fish06 said: I've just checked my gearing and it's on 9/46, should be ok? I'm going to ultra sonic clean the carb and see if that helps, thanks so far. Sounds like a plan?
October 22, 20188 yr check chain tensions and also the rear cush drive pins in the rear hub -they can become worn and and give play - also swing arm bearings if worn can give play .
October 26, 20188 yr I used to run idle super low (I'm not a lover of clutching through anything but ridiculous corners) and would agree with you. I now run slightly faster and apply rear brake which might help smooth out the lower snap. Just understand the bike will pull in with the brake applied.
October 29, 20188 yr Author I've ultra sonic-ed the carb and internals, turned the tick over down a touch and have the air screw at 2 turns out (it seems happiest there), I can do figure of 8's with the throttle almost shut and no clutch, but as soon as you touch the throttle you get that snatchiness (not sure that's a real word) which is off putting, I'll try it in a trial this winter and see how I get on with it, much prefer my TY175 though cracking little bike. Thanks for all the replies.
October 29, 20188 yr Are you perhaps expecting two stroke smoothness from a four stroke? They are a bit harsher off the bottom - eased by having what may feel like too high a tickover. In comparison with a TY 175 it will seem particularly bad as the TY has a very smooth power output, not least due to gearing and low power (compared to a typical 250 for instance). Edited October 29, 20188 yr by 2stroke4stroke
October 31, 20188 yr On 10/29/2018 at 9:05 AM, fish06 said: I've ultra sonic-ed the carb and internals, turned the tick over down a touch and have the air screw at 2 turns out (it seems happiest there), I can do figure of 8's with the throttle almost shut and no clutch, but as soon as you touch the throttle you get that snatchiness (not sure that's a real word) which is off putting, I'll try it in a trial this winter and see how I get on with it, much prefer my TY175 though cracking little bike. Thanks for all the replies. You need a British four stroke if you want smooth bottom end power. See if you can bag a ride on a decent BSA C15, lovely smooth power.The Honda four strokes always lack flywheel effect to my way of thinking,but can be made VERY nice,a mate has an RS250t which is super smooth.
